Question about Intermatic Inc. ST01C Digital In-Wall Timer
I installed the Utilitech self-adjusting timer exactly as shown in the instructions: black to black, red to red, green to ground and white to neutral. It didn't work. I swapped out all of the colors. Still didn't work. I bought another one just in case I got a defective one. No joy. I took a picture of my wiring to our local hardware store and they thought it looked fine. This should work as we had a timer in that same spot when we lived in this house 5 years ago. Help!
Here's a Utilitec page with step by step wiring help:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
I've done testing on the Utilitec.
Utilitec timers are made to replace 2-pole switches where one switch (or one timer) controls the lights.
If display shows after wiring timer, then wiring is usually correct
If display does not show, then electricity is OFF
If you are replacing a 3-way switch, the Utilitec is wrong timer
If the wiring is wrong the Utilitec will not function.
If you do not have a neutral wire in the box, the timer will not function
Posted on Oct 12, 2010
Utilitech digital timer
The timer could have been miswired.
Mar 12, 2014 | Hardware & Accessories
Installing utilitech in wall countdown timer
None of the answers are helpful. First, this is a question about installation and not operation so clpalmer976 is worthless. And no, if you read the question it was not a 3 way switch. If you hook it uplike ridley says, the light is not powered. Read the question. The red wire powers the device. The problem is "If I connect the red to the white, the switch will work in a clicking, pulsating fashion." The red has to be connected. The last suggestion, there is on info on unitech anything on the site. They are all somethings that can't read and make this site especially worthless.
Jul 07, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
Installed Utilitech 192773. The lights works, the backlight display comes on light blue but there is not numbers on the digital digital display
Reset timer, and see if that fixes problem
Use toothpick or paper clip to press reset button, or refer to instruction sheet, or copy following link.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
I have tested this utilitec timer, and using reset button will repair most problems.
If not, then Timer has 1 year warranty against defect, but it is easier to buy new timer at Lowes, and return defective timer in new package and report timer as defective.
Jul 29, 2012 | Hardware & Accessories
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
I bought a Utilitech Self Adjusting In-Wall Timer #0192773. The Timer has 4 wires....a black wire...a red wire...a green wire...and a white wire. The switch that I am replacing has 2 black wires and a bare...
The reason there is 2 black in the wall is because a standard line breaking switch was used. Meaning the hot side of the light was the black wire once broken light goes off. You would hook the black from switch to black in wall and white from switch to other black in wall green is ground and red put wire nut on. Red is for a 2 switch system. Where one of two switches in same room controls same light. Its not needed. Take caution when doing this trun light on goto breaker box and flip breakers till you find the right one that powers that light. once lights off then do your thing replacing.
May 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
Purchased utilitech 0192773 self adjusting wall timer. planning on installing in garage wall switch box for outside lamp posts, 3 total. the wiring in switch box consists of grounds tied together, 2 whites...
you got the wires you need. add switch's white to the white bundle in the back; green to grounds, red to the black going to the light; black to the other black. worked for me!
Jan 29, 2011 | Computers & Internet
I just purchased a Utilitech Self- Adjusting Wall Timer. I need some direction on how to hook the wires up. Out of the wall I have a RED, BLACK, BLACK (Common) and a bare ground wire. I have connected the...
ive sussed it,,, do not connect the red wire!!! black wall hot to black , other black to white and leave red of...just tape it up lol and others as normal thumbs up i hope
Aug 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Trying to replace Intermatic with Utilitech inwall timers. Have 2 black wires in wall box with other switches for other lights. Which of the Utilitech 4 wires- black, red, white & green get conected to...
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Apr 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
479 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
