Indesit WG820 no power in spin
Hi, my washing machine indesit wg820 is not spinning properly.The drum is fully turning but very slowly meaning the clothes are coming out dripping wet. Been advised that it could be the filter or pump..I've found the pump but cannot see a filter. Any ideas?
    President:
  • 1,294 Answers
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Posted on Jun 01, 2008
Hi there, my Indesit W133S front loader tub washing machine has stopped spinning, it made a funny metallic scratching sound mid cycle and then wouldnt spin. When I removed the washing even the empty drum...
Taking a guess is all that is possible...
The drum bearings have seized.
Something has broken and jammed the drum drive pulley.
Something has become jammed between the washtub and drum.
Your next step is to remove the top of the cabinet and examine the drive, ensure the motor still spins ok and the belt is intact, pulley not broken, etc.
If you find nothing wrong the task becomes fairly major as the cabinet will probably need dismantling in order to remove the front of the washtub for a closer inspection.
Mar 05, 2018 | Indesit W 123 Front Load Washer
I have an Indesit washing machine and when it get to a fast spin cycle it sounds like it is washing a load of rocks. It is very loud. It doesn't seem to do this when the drum is turning slowly.
Hi.
It soumds to me like the main drum bearings have failed.
From the front of the washer, put your hand inside the drum and spin it round, it should be noise free, if it feels rough or is grating or rumbling, then the bearings have failed.
This is quite a big and involved repair to undertake.
Feb 06, 2011 | Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit WIDL1265 - Noisy on Spin
Hello, this is a symptom of drum bearing wear, and what you need do is to check the wear to see if the inner drum moves up and down relative to the fixed outer drum. It should only moves a minutes amount. If it moves more than a millimeter or two, that means it is probably worn bearings and you will need to replace it.
Thanks
Jun 10, 2010 | Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Indesit moon not spinning as it should
my machine is similar...............but has an extra rinse button which adds 5 minits to the wash.....but spins faster to get rid of extra water...............see if you have extra rinse option......
cheers
Jul 24, 2017 | Indesit W 123 Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Washing Machine faulty
water in drum after washing
May 06, 2008 | Washing Machines
Indesit WA105 - drum is loose and fails to spin
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Jul 23, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
279 people viewed this question
Top Washing Machines Experts
