Question about Ford 8N Tractor
My 8n ford is leaking exhaust at the manifold. Is there a manifold gasket between the exhaust manifold and engine?
  • 58 Answers
SOURCE: Replacing an intake manifold gasket on 1993 ford ranger 4.0
I've replaced several of these gasets and they were made that way.
It wouldn't hurt to call a different autoparts store and ask them if theirs are made that way.
Posted on Jan 07, 2009
  • 42 Answers
SOURCE: Coolant leak on 2001 Taurus.Coolant seems to be
heaterhose is in that general area. most common leak is that spraying aroung so it looks like something worse
Posted on Mar 17, 2009
  • 398 Answers
SOURCE: 1988 Ford F150 exhaust manifold leak
autozone.com repair section
Posted on Apr 03, 2009
  • 204 Answers
SOURCE: LOSS OF POWER EXHAUST LEAK WHERE MANIFOLD PIE CONNECTS TO EXHAUST
if the exhaust is just cracked i wouldnt worrie about the engine because you still have a lot of backpressure and it should not burn a valve. but replacing the header is a good idea if the header itself is cracked. and to tell you the truth your mechanic should be responsible for the cost of the repair since he broke it in the first place. In the shop i own if one of my mechanics breaks something it comes out of my pocket to replace. its all part of the job sometimes things just happen and you have to take the responsibility for it
Posted on Jun 09, 2009
  • 10 Answers
SOURCE: 95 f150 4.9L leaks from exhaust manifold with a
You might have a warped exhaust manifold, or head. You can check this with a straight edge and a feeler gauge. Also check for hairline cracks.
Is the carbon on the outside of the injectors, or on the inside? If it's on the inside then it could be from cheap gas. Do a fuel injector service to get them cleaned out.
If you had exhaust leaking into the intake manifold you would definitely know about it(backfire).
Posted on Dec 01, 2009
Exaust intake leaking
It's exhaust manifold. There are two manifolds, the intake manifold in the valley between the cylinder heads, and the exhaust manifolds, one on each side of a v figured engine.
And, yes, a leak in the exhaust or the intake will make it run lean. If the leak is close to the engine, it can do harm to the valves, too. There is a gasket between the exhaust manifold and the engine block. Likewise, there is an intake manifold gasket between the intake manifold and the block.
Apr 04, 2014 | 1998 Ford F150 Regular Cab
Exhaust leak
leaking manifold gasket, cracked manifold, or manifold to exhaust gasket.
Dec 16, 2013 | Ford Focus Cars & Trucks
What cause my 2000 lexus es 300 exhaust manifold to get hot
The exhaust manifold is going to get hot, this is where the engines exhaust flows through. these tempertures reach high temps,
If the manifold is glowing hot then theres a problem.
Sometimes people say the manifolds are getting to hot because they see them smoking. The reason on most of these cases is due to a leak, aleak from a bad gasket like a valve cover gasket. Engine oil leaks down on to the exhaust manifold causing smoke. make sure there are no leaks .
A few reasons that would cause exhaust manifold to heat up more than normal would be a engine thats running rich, this may be due to a leaking injector or a poor running engine. Another reason may be that you have a plugged cat. converter.
The Exhaust manifolds can reach about 600 degrees, the last thing is people hear the metal expand or contract and think there are getting to hot , this is normal.
Please let me know if there is something else i can help you with. thank you and have a good day.
Mar 18, 2012 | 1993 Lexus Ls 400
Im buying a car through a private sale and he said the 2000 Ford Focus has an exhaust leak. how do you fix that? is that expensive?
It really depends on where the exhaust leak is. If it's in the piping or the muffler, then it won't be to bad fix with some over the counter stuff available at your local parts store. However, if the leak is in the manifold, then you could be lookin at replacing an exhaust manifold gasket. If it is in fact coming from the exhaust manifold, try tightening up the bolts. If work has been done on it before, there is a good chance one or two of the bolts could be loose or improperly torqued. The other thing to look for is a warped manifold, but that usually only occurs if the engine has gotten really hot. I hope this helps in some way.
Mar 23, 2011 | 2000 Ford Focus
2000 mustang v6 has p0174 code. no leaks from hoses or anything external (vacuum) exhaust has no leaks. car runs bad uphill $ shudders from stopping at stop sign and accellarating. p0174 indicates bank 2...
Hi, have you checked for intake manifold gasket leaks? Pretty common on Ford V-6. With engine running, spray carb cleaner on the gaskets. If the engine speed changes, you have a gasket leak (yes, driver's side of the manifold).
Thanks for using FixYa.
Jan 23, 2011 | Ford Mustang Cars & Trucks
Blowing anitfreeze out the tailpipe. I know this means a head gasket. When the engine runs, it blows antifreeze out the passenger side of the engine at the exhaust manifold by the middle cylinder. Does...
could be just head gasket and bad exhaust manifold gasket (coolant leaks past head gasket into exhaust port then leaks out of exhaust manifold gasket)
or it possible that head is cracked too
Only way to know for sure is to remove head and inspect it
Jan 06, 2011 | 1986 Ford Bronco II
Exhaust makes a loud tick when first started
usually an exhaust leak, at exhaust manifold to head, broken stud maybe. Use a piece of hose to your ear and listen at manifold.
Dec 06, 2010 | 2002 Ford Mustang
2001 ford taurus 3.0(2) codepo174, changed oxygen sensors and fuel filter code still comes up on memory
This code is usually caused by leaking intake manifold gasket on the front side. With the engine running, spray carb cleaner or ether on the gaskets. If the engine revs at all, you have a leaky gasket. If not, check for other vacuum leaks in anything attached to that side of the manifold. If you have more questions, please let me know.
Oct 27, 2010 | 2001 Ford Taurus
Ford focus 2002, When accelerating sounds like exhaust is blowing. Replaced exhaust but noise still there, any ideas?
Check the EGR valve pipe connection and mounting gasket, also check the EGR pipe connection at the exhaust manifold. Check the exhaust manifold for cracks and gasket leaks, hope this helps, let me know.
Jul 01, 2010 | 2002 Ford SVT Focus
WHERE TO LOOK FOR EXHAUST LEAK
There are several areas to check for possible exhaust leaks. i will list them below.
1. Exhaust manifold gaskets - This will be the most common area. There is a gasket that separates the block from the exhaust manifold. these gaskets can fail, thus, causing a exhaust leak at the manifold.
2. Lower manifold gasket(donut gasket) - This will be a possible leak spot as well. This small circular gasket is placed in between the upper exhaust pie and the lower side of the manifold. It basically separates the pipe from the exhaust manifold.
3. Exhaust pipe - The entire pipe can rust overtime, thus, creating small holes along the pipe structure. These holes will cause the exhaust to leak ,thus, filling the vehicle will moderate fumes and causing louder than normal engine sounds during revving.
4. Muffler - This component can also deteriorate to the point that it cannot filter out the noise. It will also cause leaks as well.
You will find the leak in one or all of the areas stated above in the list.
Jun 13, 2010 | 2006 Chevrolet HHR
Ford 8N Tractor Logo
299 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
Rob Woolcock
Rob Woolcock
George Christ
Are you a Ford Toy Expert? Answer questions, earn points and help others
