Question about Sport & Outdoor - Others
I just purchased and installed a Minn Kota 70 PD V2/AP 60" - 24 volt trolling motor. Whenever I apply the "gas pedal", whether by foot pedal (moment or constant), co-pilot, or auto pilot, the thrust motor cycles on and off, on & off, etc, never reaching a full speed or constant running mode. The left/right steering works just fine. I have checked all of the wiring, plugs, etc and found nothing which effects the issue. The unit is brand new. The co-pilot is from my previous motor which got broken. 970 375-4818 Office 907 903-3880 Cell Thanks!
  • 10,865 Answers
Hello. IF this is anew motor definitely return it as it has an internal fault. Opening it up and working on it will make the warranty null and void. Joe
Posted on Oct 12, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    I have lost speeds 1 thru 4 on a minn kota edge 70. 5 still works fine where should i start troubleshooting
    Hello Richard,
    It has been some time since I have been around trolling motors but it sounds if the variable speed sensor or switch is either corroded or burnt out. Since you had the speeds and they are slowly disappearing it sounds if the switch is failing. If you are somewhat mechanical and know how to test using a volt ohmn meter you can check the switch this way to see if it is the switch. If the switch tests fine then your circuit board in the motor head or foot pedal has gone bad.
    Hope this helps some
    Oct 29, 2014 | Minn Kota Edge 70 45" - 1355970
    On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
    You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
    Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Can you wire a minn kota foot control
    .....I think so ;)
    Here's a schematic, complete with wiring diagram:
    Maxxum 70 Bowmount
    Best of luck!
    Mike
    Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    You need your serial number of the trolling motor, length of shaft, and thrust poundage.
    or you could call Minn Kota direct and give them the same information at 800-227-6433.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Hook up for one battery operation for minn kota trolling motor
    I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Sport & Outdoor - Others Logo
    76 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
