When I swich on the PC power is kicking on and off
  • 27,725 Answers
Test or Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Oct 12, 2010
1997 Suzuki VZ 800 Marauder wont start
It sounds like a starter relay.the fact that the bike will start when you jump to the starter motor supports this.Your starter relay will be close to the battery and will have four wires going to it ,two lighter wires and two battery size.cables.It will be about two inches long and be black on top and metallic below.Service is by replacement only, I think they are around $25-$35.Just remember you have battery power going to the one side,don't let it ground on the frame.good luck
May 06, 2014 | 1997 Suzuki VZ 800 Marauder
I have a HP630 but my pc don't want to swich on
disconnect the power supply, hold down the power button for 1 minute and re insert power try switching on if not try pushing the power button and the disc tray button at the same time
Nov 20, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Thefurnace and the ac will not kick on its not the thermostat
check power, fuses, door safety swich's, disconnects,,,,, make sure you have proper line voltage going to the units............
May 10, 2011 | Heating & Cooling
Is there a relay switch that controls the wipers moving back and forth?
There is a fuse that controls the wipers. Make sure you hear the motor kicking on and off. If it is kicking on, the motor may be shot. If the fuse and motor is good, it may be your wiper swich.
Feb 23, 2011 | Pontiac Grand Prix Cars & Trucks
Fuel pump will not turn on i just changed it and it still will not turn on
Check the fuel pump inertia switch. If you hit something or something hit you, this swich turns off power to the fuel pump. The switch can also go bad and the pump won't get power. Check around the kick panels and trunk for the switch. If you can push it down, then it was triggered.
Mar 04, 2010 | 2001 Ford Mustang
Dodge Ram AC not blowing cold
By pass both pressure switches one at a time with small wire or a paper clip. If comperssor kicks on replace the swich that you bypassed.
if not it could be the fan clutch ot the compressor. Compressor runs about $400.00
Jun 15, 2009 | 2000 Dodge Ram 1500 Truck
Need a diagram for the powerswich hdd led reset swich speaker setup on the main board
simple just(google it)on google search engine with the above info you have typed in and you wil get reviews to diagrams,good luck.
Apr 12, 2009 | Computers & Internet
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
thanks
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
Power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can not swich on even if the battery is ok
Remove both the AC cord and the battery for 1 minute. Then plug in AC only and see if PC will power up. If not, next connect both AC and Battery.
Be sure to press and HOLD power button for >5 seconds when powering a Laptop.
Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
