Question about Hotpoint Dryers
Mod # DLB2650BELAD Hotpoint GE dryer, what will cause the tub to become unbalanced? how do i resolve this problem? sound like it scrapping against metal
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
  • 126 Answers
SOURCE: dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Posted on Jan 11, 2009
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
Posted on May 22, 2009
  • 2468 Answers
SOURCE: GE electric dryer (model #: DRSR483ED2WW) sounds
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Posted on Feb 01, 2010
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
Washer make sounds, like brake sliding during mid cycle
Could be that your washer is unbalanced internally causing the tub to be rubbing against something else internally. Also check that your fan belt has automatic tensioning when it spins the tub.
Jan 31, 2015 | Washing Machines
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to...
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Mar 12, 2011 | Washing Machines
The drum seems to have become detached from the inside and has been scrapping against some plastic
The support bracket on your inner tub has probably broken. It involves replacement of the inner tub (drum) and probably the outer tub depending on the extent of the scraping. The parts will have a 5 year warranty, but the labor/service charge is your responsibility. Labor can be a bit pricey because of the extensive labor involved.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tub bangs loudly
there may be 3 to 4 load springs on the underside of the machine that attatches to the tub. if one of these breaks which often do on my machine. They will cause the machine to become unbalanced and bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
54 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
