Question about GE Profile JTP18 Electric Single Oven
Model number on my GE oven tag states. J SP31WOT1WW But I can not find this as a good model number. What am I missing? I need to find a new oven bottom heating element. Thank you
  • 1,543 Answers
Try disregarding the zero. Use JSP31WT1WW.
Posted on Oct 12, 2010
Hi all, I have posted a few photos , it would be a great help if anyone could identify this model and give me the missing marks of the oven. Thanks.
Look at the bottom of the oven . From the inside, remove the racks. You can remove the bottom metal plate which will expose the tag with the model number on it.
Oct 22, 2016 | Ovens
I just tried plugging my new oven in (model number jrp24) and my GFI flips. The oven is off and the wires are connected properly. I live in a country that requires 220v, even though the oven says 120/
The model number according to GE says this is an electric oven.
It states that this oven will only be Hard wired and not supplied with electricity using a Plug. If it is gas, only one leg of the 220 volt power will be utilized. and the other usually colored white indicating natural, or green indicating Ground. Or, there will be a switch like on all computers that you will simply move to the selected voltage of the country that you live in and this will correct the high or low voltage. I hope this helps, without the full model # I will not be capable of knowing the actual voltage that the appliance works with.
Sep 14, 2014 | GE JRP24 Electric Double Oven
How can i get an owners manual?
Good Afternoon Friend, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire Gas Single Oven (FGB24S5A) and that you are looking for the manual. I have successfully located the Owner's Guide. However, if you need a different manual, please provide me your model number. You can typically locate the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door on a wall oven. If you have a range, you may find the tag in the storage drawer, on the right side. Hope this helps!
Frigidaire Manual Search Results
Jul 13, 2014 | Frigidaire FGB24S5A Gas Single Oven
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
Microwave display just flashed F6 error code. Only mention in manual is for lower oven display.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and remind us that it displayed an F6 error code.
Nov 26, 2009 | GE JKP85 Electric Double Oven
I need a AC-Motor
Guten tag Thoma,
The only place I could find that may be able to help you is this company in the US.
http://www.1sourcecomponents.com/
The US telephone number is 631-642-2479.
They say they can find ANY part you need, although they did not have the exact model # you requested.
I hope this helps. Have a good day and thanks for using Fixya.
Wayne
Jun 09, 2009 | GE Ovens
Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
134 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
