Question about Toshiba Computers & Internet
I have toshiba notebook A200.I have been using a USB mouse,and I now can not get the touch pad to operate.Plerase advise me what I can do.I have tried FL F9 to no avail.
    Problem Solver:
  • 13 Answers
If you unplug the mouse and then start up the machine does the touchpad not work at that point?
Some systems have a settings in BIOS that prevent the touchpad from working if a mouse if connected.
Try unplugging, start up and if the touchpad doesn't work, shut down and go into the system settings and turn on the touchpad (if turned off).
Also, make sure the device manager doesn't show any Yellow Exclamation points, meaning a bad or missing driver. To get to Device Mananger, go to control panel, system, hardware, device manager (in Windows XP that is).
Posted on Jun 01, 2008
  • 85 Answers
What is your actual problum do u want to use mouse only or u want to use both ok
also contect ur supplyer
The mouse on my laptop doesn't work, but the external mouse plugged into the usb does. Any suggestions?
Touch Pad setup with the usb mouse installed for easy navagtion
check the device manager for mouse mouse and other devices
look for nthe touch pad label
look see if it is running ok and enabled.
Make sure it is.
Go to control panel open the mouse icon
touch pad mouse properties
Here is where the controles for external and internal mouse settings will be found.
The rest is up to you
Jun 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hi< I have an a200 sattalit pro and I have
use external mouse instead or any wireless device..
Mar 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba satellite a215 disable mouse pad, is this possible.g
I think you meant touch pad. so on every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Nov 26, 2009 | Computers & Internet
Touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Sep 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
    When typing on toshiba the curser skip and actually moves
    It might be that your palm is brushing across the intel touch pad (mouse pad) as you're typing?.. try holding down the function key (Fn) (on the lower left corner of the keyboard) while pressing F9 (this activates the "Toshiba Flash Cards Menu" and is a keyboard shortcut to toggle off/on the touch/mouse pad. You can turn it back on this way too. I almost always use a conventional USB mouse with my laptop for this reason and because it's faster than fiddling around with the pad, IMHO).
    Dec 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
    Touch pad not working properly
    Plug in a usb mouse and go to control panel>system>hardware>device Manager (if using XP) or control panel>system>device manager (if using vista) and right click on pointing devices, unistall the touch pad and reboot - remove the usb mouse and the touchpad will be installed again as new hardware. I hope this helps
    Nov 28, 2008 | Toshiba Satellite A135-S2276 Notebook
    Touch pad possessed.
    To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
    Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
    Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
    For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
    Touch pad failed.
    Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
    Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
    Hope this helps.
    Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
    I need to disable touch pad and use a usb mouse
    Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
    Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
    Enabling computer mouse
    did u hit fn key or botten above mouse turn the mouse on ??> buy usb one mini
    Jan 16, 2008 | Toshiba Qosmio G25-AV513 Notebook
    Computers & Internet Logo
    50 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
