My cdrom drive stop working - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Control panel administrive tools device manager scroll to cd/dvd rom drives right click you will see update driver,disable,uninstall,properties select properties,then general to troubleshoot or driver to either update,uninstall,roll back driver
hope this helps
Posted on Oct 12, 2010
Hi..my compaq CD drive is not working The CD drive is not seen in my compuer
hello
shut down the computer completely and disconnect power cable connection. make sure all cables to the CDROM are connected properly. If they are , remove the cables.
Remove the CDROM, clean it from any dust or debris with air compressor inside bay area and around the connection circuits. Replace the CDROM back into tray and start up computer. If problem persists. go to www.hp.com , retrieve CDROM part number and get a quote for replacement CDROM drive. The one you have obviously does not work at all.
Jul 16, 2011 | Compaq (120192-B21) CD-ROM Drive
Can I boot my e-machine M6810 from a usb cdrom drive? My build in cdrom fell apart and my usb cdrom works when the computer is on, but I can't seem to boot from the new cdrom I have tried changing the...
in short - yes! any e-machine, or indeed any computer build in last 5 years can be boot-up from usb port.
you need to enter bios and setu-up as first boot-up device "other", "boot from another devices", i do not remember which one is actually in this particular bios
plug in your external usb cd-rom, or indeed bootable usb-memory or bootable hdd and they should boot and work as they are on the computer.
another issue, internal cd-rom cannot be really disabled as only mechanical, external part stop working, it' logic part is still there and cmoputer therefore "see" it. you can disable it by downloading newest bios which have bit more power and tweaks than old one.
Jul 26, 2010 | E-Machines M6810 Notebook
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
When i try to open a cd it is saying that the e. drive is not accessible
Have the CDRom replaced, it has gone faulty. The small board on the cdrom drive has stopped working.
Thanks: Please leave comment..
Oct 06, 2009 | Gateway MX6920 Notebook
DELL INSPIRON 1525 not recognizing CDROM Drive
  1. ensure drive is recognized by the BIOS (It should be ID'd by model in BIOS
  2. If drive is seen normally in bios, then try the fixit utility in this link: http://support.microsoft.com/kb/314060
  3. See if you can boot to the drive using your Vista DVD and run a repair my computer from DVD
  4. If none of the above works, replace the drive. If system will boot to DVD, then reinstall Vista
Sep 29, 2009 | Dell Inspiron 1525 Notebook
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Toshiba Satellite A105-S2236 Laptop
The drive is faulty. You need to replace the drive. The reason the DVD still works is because a combo drive has 2 different lasers; one for the CD and one for the DVD. So the CD laser is faulty.
Jun 29, 2008 | Toshiba Satellite A105 Notebook
Acer aspire 5310 cdrom drive cannot be recognise or not working
my cdrom drive is not working,what will i do or what would be the possible causes
Feb 21, 2008 | Acer Aspire 3680 Laptop
CD-ROM Not responding
you can get the disc out by inserting a pin in the small hole on the cd draw, but when this happens it means the laser is failing to read the disc and the cdrom is failing, unfortunately the cdrom cannot be changed in the acer notebooks.
Nov 06, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
