Question about Ctm HS-2800 Power Wheelchair
As the battery properly charged hs 2800, two LEDs flash yellow when I turn it on.
    Novelist:
    Champion:
  • 232 Answers
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Posted on Oct 29, 2010
Will not charge when plugged in to electricity
1) Order a new charger. 24 volt 3-amp.
2) Replace the batteries if they are over a year old. Usually two each size U1 gel\AGM or SLA 12volt 34amp-hour.
Nov 01, 2013 | Ctm HS-2800 Power Wheelchair
C.T.M HS320 power chair wont go with full charge and all connections,fuses good.
Could be in Lock Mode. Don't know your controller type but VSI Profile LEDs will scroll from left to right when in a lock mode. Identify your controller and get lock/unlock instructions.
Mar 08, 2013 | Ctm HS-2800 Power Wheelchair
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
It never holds a charge, looks charged in the morning, but goes down to one red bar in an hour or two. Then all speed lights will flash with a yellow flashing light sometimes below them, looks like a...
Babble replace the batteries and check out my tip on charging your new batteries. if Medicare paid for your chair then they will cover most of the cost of new batteries contact the provider that sold you your chair and ask if they can change the battries for you Hope this helps
Mar 01, 2011 | Ctm HS-2800 Power Wheelchair
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
Why would my less than 2 months old batteries die after 15 minutes run time?
Has your power chair been stored or not used in a while? Have you been charging the batteries regularly? Is the charger plugged in to a working electrical outlet, turned on and plugged into the power chair properly?
If the batteries have not been maintained properly, they may have become damaged that will prevent them from getting a full charge. It can happen quickly, even in as little as 1 month of storage.
When you operate the power chair is there any noise or vibration that could indicate a mechanical problem?
If you continue to have a problem, contact your dealer or manufacturer. If your insurance paid for the power chair, they may pay for repairs. Warranty may not cover repairs caused by customer neglect.
Aug 06, 2010 | Ctm HS-2800 Power Wheelchair
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can't find where it plugs into...can anyone help
the wire with the fuse belongs to external light fetures (unit does not have. It was intended for future use for external ligts)
the two yellow lights endicate problme with batteries( too low) or the module controller.
3. Left motor Fault
9.Shark Module Faul
****two yellow lights*** Module problem
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Sep 04, 2009 | Ctm HS-2800 Power Wheelchair
Ctm HS-2800 Power Wheelchair Logo
105 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Dan Apthorp
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
