Question about Canon PIXMA MX320 Color USB InkJet Printer
I turn on my mx320 and something inside the machine starts to rattle the alarm comes on and error 5011 comes on the screen
  • 1 more comment
  • Julie French Oct 12, 2010
    my cartridges don't come to the centre like normal...
    ok I did what you said and it is still rattling with the same error
  • Julie French Oct 13, 2010
    Thank you I will try this!
  • Canon Master
  • 4,737 Answers
First try this:
  • Turn off printer
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Press Resume button 2 times then let BOTH buttons go.
  • Green lights will flash and then stop blinking.
  • When green lights are solid, press the Resume button 4 times.
  • Press the Power button and the printer should turn off, if not, press the Power button once more.
  • Your printer should respond as normal..
It's also necessary to manually move the (gently) cartridge carriage, you can give a try, in most cases, the carriage is stuck.
Let me know.
Posted on Oct 13, 2010
    President:
  • 3,278 Answers
Hello.
Give this a try:
Please try resetting the printer:
1. Verify that the unit is switched on.
2. Open printer and remove both cartridges.
3. If the power cord is removable, unplug it from the printer. (not from the outlet). If it isn't just unplug it from the wall outlet.
4. Wait 30 seconds.
5. Plug the power cord back into the printer.
6. Open the top cover and reinsert both cartridges.
7. Turn the unit on.
Hope this helps.
Posted on Oct 12, 2010
  • NinaE Oct 13, 2010
    Hello, again.
    The 5011 error is a carriage error. Another suggestion is to open your printer cover and look for obstructions. If you don't see anything, remove and reinstall your cartridges, both color and black.
    When you open the printer, the carriage should slide to the middle of the printer. If it does not automatically slide over, see if you can push it over gently.
    If still a problem, you may need to buy a new carriage, which is probably not be cost-effective.
Printer error 6000
Hi check paper feed for blockage. & Turn power of at the PowerPoint..& turn back on.good luck..
Aug 22, 2016 | Canon PIXMA MX320 Color USB InkJet Printer
I put it on vcr and put a vhs in it, it comes plays for about 5 seconds then it stops says error 1 and it completley shuts my player off, How would u fix this?
plenty of problems possible. I would pick the machine up and shake it, see if something rattles inside, if so see if you can get it to come out of the door, if not the cover will have to come off. if you are lucky it will be something a kid stuck in there or a part from a cassette, if not the machine is broken and would need to go to tech or goodwill. if it doesn't rattle you will have to take the cover off and you can watch the tape as it starts and will be able to see directly what is happening to make the tape stop. vcrs will stop and shut off if the tape is getting stuck or if something is broken.
Jul 22, 2015 | Televison & Video
Error 5011 cannon MG 5340
Dear
The printer error has occurred.
solution
1.Turn off the machine and unplug the power cord from the power supply.
2.Plug the machine back in and turn the power on.(if you disconnect the power plug, all the faxes stored in the machine's memory are deleted).
If the above solution has not resolved your error, please contact your nearest service center.
Thanks.
Feb 26, 2015 | Cannon Office Equipment & Supplies
How do i fix error 5011?
The error message indicates that the print head may be stuck. Here are some answers I found for you:
Canon Printer Error 5011
Fix your printer
Dec 31, 2014 | Canon PIXMA MG4120
Cannot get brand new printer to work.
This information is from a Canon, I don't see an error 5011. Only the following info. below.
"****" is displayed in the alphanumeric character and depends on the error occurred.
  • 5100/5110 is displayed:
    Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving, and turn on the machine again.
    Important
    • Be careful not to touch the components inside the machine. The machine may not print out properly if you touch it.
    • If the problem is not resolved, contact the service center.
  • In other cases:
    Turn off the machine, and unplug the power cord of the machine from the power supply.
    Plug the machine back in and turn the machine back on.
Nov 15, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My cannon MX320 printer light are flashing both the on and alarm button - message contact service center, printer error has occurred at the botton of the sceen it shows B200
This error refers to a voltage problem within the print head. Usually the fix is a new print AND the main logic board.
Personally i feel its an end of life error and you should consider replacing the machine as the cost of repair is more than it would be to buy a new printer.
Sorry
Aug 25, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I just install new CANON Pixma MX870 and got error 5011 message on display... I am able to print from computer, but copy and scan functions did not work. Turning power off and back on reset the alarm, but...
According to this forum post, it sounds like a hardware problem.
It is possible that the scanning mechanism is broken as copy and scanning both require the same technology.
Error Code 5011
Nov 16, 2017 | Office Equipment & Supplies
Canon PIXMA MX320 Color USB InkJet Printer Logo
815 people viewed this question
old marine
old marine
