Question about Kitchen Appliances - Others
How to clean electric griddle
Grease buildup on eclectir griddle that is not submersible
  • henr2y Apr 12, 2009
    I used pam spray on my black and Decker electric griddle and it left a gummy stain that I can't get off. Any ideas to remove so I don't damage the finnish?
  • Anonymous Mar 14, 2014
    Need a new Rival Griddle grease tray
    Genius:
  • 1,036 Answers
Hi there!
When it is warm, use a spray cleaner and paper towel to wipe up the grease.
Wooden or non-stick spatulas make excellent scraping tools to take the worst off first.
Use paper towel to wipe up.
For really stubborn deposits, use an oven cleaner - and cover with plastic film. Check in 1 hour, and clean as above.
Soda Crystals dissolved in hot water are excellent at cutting through grease, but may affect aluminium. They work out cheaper than many commercial products.
Hope this helps you.
Posted on Jun 16, 2008
    Sergeant:
  • 179 Answers
If you use stainless steel griddle then clean it with soapy water and nylon scrubber. But for cast iron griddle use paper towel and hot water, clean it properly and dry the surface.
You can choose best electric griddle by these reviews and top 5 non stick cookware reviews:
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Posted on Jul 31, 2015
Where is the grease trap located
usually under the griddle and I would think toward the front
Mar 04, 2015 | Wolf Range Cooktops
A guest used the electric griddle on my Jenn-Air. She made terriaki chicken and now the griddle has balack cooked on stuff ( probably from the sugar in the terrikaki sauce. I've had this griddle for...
if it has slightly raised sides or a fat drain
let it heart up and then used water on the hot surface to steam loosen the crud
you could put a bit of washing up detergent in the water ( just a few drops )to assist in breaking down the surface tension and release any grease
The same as cleaning a BBQ plate before using it
Nov 18, 2017 | Jenn-Air JED8230 Electric Cooktop
How to use both sides of the weber cast iron griddle
After both sides are seasoned, you simply remove the necessary grill grates and replace them with the griddle. Or set it right on top of the grates. However, the grease drain hole may not work that well, when sitting on top of the grates. Since the ones that I have seen look the same on both sides, I don't see any advantage in using both sides. Certainly would make it harder to keep seasoned.
Jul 09, 2011 | Weber Genesis Silver B Grill
I have a griddler that has been used for greasy cooking--looks baked on. How do I clean the griddler? Water won't do it.
The best way to clean a griddle caked with grease is to turn it on and let it get hot. Then turn it off and while still hot, use a non abrasive cleanser (aka Comet, Bon Ami) with a nylon scrubber to cut through the grease. If the griddle does not have a non stick surface, you can get "screens" to work the grease free. This is what is used on professional grills (usually on a nightly basis). If all else fails, most oven cleaners will do a nice job.
Jun 16, 2011 | Vacuums
Can you cook hamburgers and pork chops on the griddle hot plate?..if so, should there be a drip pan beneath the holes in the griddle to catch the grease?
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
Aug 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Garland range griddle top
make sure your unit is leval if you have alarge build up you will have to remove griddle and claen then reinstall
Sep 08, 2008 | Garland PS-36G-4-26 Gas Kitchen Range
Griddle top for older Garland 283 gas range
Hi, it may not, depending on the age difference of the units, the grease catch, etc.. contact Garland at www.garland-group.com , or call 1800 424 2411, the parts department should be able to tell you at least. Hope that helps, and thank you.
Mar 10, 2008 | Garland H283 Gas Kitchen Range
Kitchen Appliances - Others Logo
2,745 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
