Question about Aurora Electronics AS890C Shredder
Does not turn on. my husband accendently tried to shred about ten papers all together and now it does not work.
    Sergeant:
    Champion:
  • 387 Answers
Have somebody check the fuse unless its over heated and burn the motor
hope it will help
Posted on Oct 13, 2010
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Shredder goes 1/3 and stops has to be reversed the forward also paper comes out punched but unshredded
its the combination of plastic parts in the shredding device . the plastic tongs part craks off then the metal binds . paper builds up in that area .
its unlikely you can fix it .
youll put ur eye out trying.
Aug 03, 2014 | Industrial Paper Shredders Office...
I'm an intern at a law firm and i shred papers everyday. Sometimes the shredder stops working and when i feel it it feels really hot so i assume its overheated due to shredding (i shred probably 1000+...
you may have just been trying to shred to many papers at a time. you could just remove them and turn the shredder on. if the sound is still being made there is a good possibility that the shedder is going to be completely useless soon and you may want to look into a new one.
Jun 30, 2011 | Office Equipment & Supplies
The aparatus that pulls the paper into the shredder doesn't work
Check to see if cutting shafts are turning in either forward or reverse operation. If not and you can hear the motor running the take off cover and check plastic gear drive train...probably something broken in there.
May 25, 2010 | Aurora Electronics AS662C Shredder
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Will turn on, run in reverse, but will NOT shred...
First try unplugging the power cord for ten minutes and see itf it reset.
Many model also have a reset button inside, find it and keep it pressed if the first solution did not work.
Sep 14, 2008 | Royal 10X Shredder
Aurora Electronics AS890C Shredder Logo
230 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
