Question about Motorola TalkAbout T5000 2-Way Radio
There is a way to keep the radio from "beeping" after a transmission but i cant find it in the guide as to how to go about turning that feature off(?). The radio is 3-5 years old if that makes a difference. We have had it off in past hunting seasons (to keep from spooking deer) but cant seem to figure it out this year
  • Motorola Master
  • 1,654 Answers
It should be able to be turned on or off by holding the + (plus) button in while turning on the radio. We could not find the manual directly for the T5000, but here is a link to the T5100 and T5200: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Best regards.
Posted on Oct 13, 2010
We have MotorolaModel SX700 series. When any of them are turned on they just continually beep. What does this mean and how do I turn the beeping off?
This can be a sign of a bad or poorly charged battery. Or you might try reprogramming the radios to shut off any special features, putting the radio back into a very basic mode.
If you need help with programming here is a link to the user guide page, where you can select your model from the pulldown. http://shop.giantintl.com/Manuals.asp
Best regards.
Apr 24, 2014 | Motorola Radio Communications
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
How do I get the noise made after a transmission turned off?
You are talking about the beeps after the transmissions... This is to indicate to the other unit that the TX line is clear. It is the electronic equivalent of say OVER when talking on a one way radio.
I am not aware of any method to remove this feature. Yet.
Oct 12, 2010 | Motorola TalkAbout T5000 2-Way Radio
How do I silence the beeps on this radio
There are two features which cause the radio to make a tone or beep, before or following a transmission: Talk Confirmation Tones (aka Roger Beep) and Call Tones.
On the T6510 radio you would hold in the + (plus) button while turning the radio on, to turn ON the roger beep. To turn it OFF you would hold in the - (minus) button while turning the radio on.
Call Tones are a little more detailed explanation. You can find directions for both in the user guide on page 25: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 02, 2010 | Motorola T6510 XLR Talkabout Two-Way...
Cant turn off beep on motorola T6500
You may be referring to the Talk Confirmation Tone (Roger Beep). This feature is turned off by holding the minus (-) button while turning the radio on. See page 25 in the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
May 31, 2010 | Motorola Talkabout T6500 (7 Channels)...
How to turn off noise after you push to talk
To
disable the ”Roger” Beep feature, turn your radio off and then back on while pressing and holding Scroll +
button. The ”Roger” Beep icon will not appear on the display.
Here is a link to the user guide.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5xXX_User_Manual_E.pdf
Best regards.
Mar 28, 2010 | Motorola Talkabout T5100 (14 Channels)...
Two motorola t8550's unable to communicate
1) You did not mention the Qt filter. You might check to see if you have the Qt filter set the same on both radios. This is an additional layer of privacy featured on this radio.
2) Verify you have good working batteries. A bad battery or uncharged battery can cause a no transmit situation.
3) If these do not work, reset your radio back to a basic operation by shutting of the code, Qt filter, call tone, weather alert, Vox/iVox, roger beep, etc. At this point your radio would be operating just on a simple frequency. See if you can communicate with all these special features turned off. If so, slowly add back in the features you desire.
4) If your radios still fails to work and is less than one year old, call the 800 number on the pamphlet, have your serial numbers and radios handy. Your radio if not physically or water damaged is possibly still under warranty.
Most of the time when a set of radios has your problem description, it is the Qt filter, or possible improper use of a special feature such as call tones or iVox. These would be the first things to check.
Best regards.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Mar 09, 2010 | Motorola Talkabout® T8500R Two Way Radio
Lost my owners manuel. when releasing the talk button my radios beep. how do i turn this off?
To
button.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Nov 14, 2009 | Motorola Talkabout T5100 (14 Channels)...
Need help
Make sure that in the set-up, you do not have the feature turned on that makes a beep for each minute in use. This is a common cause.
Check the user guide for details.
Jerry G.
Jun 03, 2008 | Samsung SCH-u340 Cellular Phone
Motorola TalkAbout T5000 2-Way Radio Logo
173 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
