Insignia 42" LCD resolution > 1280x1024 w/ computer source
How can I display higher resolution than 1280x1024 when my computer is the source
BTW, my brand/model is Insignia/NS-LCD42HD (not listed below)
    Novelist:
    Scholar:
  • 100 Answers
Salutations RandomDrone,
From reading your owners manual it appears the max resolution of the television would be 1280X1024 when using the VGA connection.
If you would like to review the manual it should be available at:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-290%20NS-LCD42HD_WEB.pdf
Sorry, I didn't have better news.
Jon
Go Ahead. Use Us.
Posted on Jun 12, 2008
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Monitor gives error when i change resolution
The native resolution of this monitor is 1280x1024 @60Hz, if you set your PC video resolution higher than the monitor can support, you will get an FORMAT NOT SUPPORTED or something like that.
Are you trying to get higher resolution?
Please leave rating if it helps.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Jan 13, 2011 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
Jun 25, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
I am trying to usa a VGA cable to watch my mac book pro on my 42" Insignia 1080P hdtv. when I do I just keep getting the message not supported on teh TV... I have changed my screen ratio on my mac book pro...
Use a 60Hz refresh rate and a basic resolution (Like 1024x768), is it works, set the resolution to the native of the display (Maybe 1920x1080 @ 60Hz).
DON'T set a refresh rate higher than 60Hz for any LCD.
Oct 27, 2009 | Insignia 42" LCD Flat-Panel HDTV
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
GRAPHIC CARD PROBLEM
Hi, I noticed you posted this same problem again. Here's the answer from the first post which should answer your question.
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Televison & Video Logo
546 people viewed this question
Top Televison & Video Experts
