Question about Whirlpool Washing Machines
Good morning. Have a Whirpool Duet washer GHW9150PWO, 3yrs old, just started flashing "F" code with audible beeps at the spin cycle on the finish side. Checked owners manual under trouble shooting, followed instructions but did not fix problem. Says "F" codes are "electrical problem"....help?!?! Can't beleive on 3 yrs old and its needing repairs already!!! Sincerely, Tom G
  • tguilford Jun 01, 2008
    Sorry about the lack of response....new to this program.
    To answer your ? yes any of the preselected default cycles. Gets down to 2 minutes on the spin cycle and flashes error code 5 with a beep.
    TomG
    Well bad news....its doing it on the wash also and not the drain. help!
    TomG
    Scholar:
  • 110 Answers
Tom i need you to clarify to codes in order to help
Posted on Jun 01, 2008
  • MARLON KELLER Jun 01, 2008
    if you machince is get to the spin cycle but not proceeeding to spin you probably have debris stuck in the pump. you will need a shop-vac lots of towels and a torx 20 to take the 3 screws of the kickplate off once yuou have the kickplate off you will see the pump slowly untwist the the filter cap while using the shop vac to get the water up once you have all the water out which will be about 4 gallons remove the filter from the drain pump and clean it out and reassemble
    you definitely need a service tech sound like the main control board is bad
    Genius:
  • 3,587 Answers
Well..sounds like perhaps the control board is having a fit..unplug it first, let it discharge(usually around 4 min) and then have a go at it again. Does this occur on all cycles?
  • Patrick Michaels
    Patrick Michaels Jun 01, 2008
    sounds like a service call is mandated...that appears to be a control board, or pump or relay issue..
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Hi
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model Ghw9150PWO beeps and flashes F then H then stops.
F/H= No water detected entering the machine make sure your valves to the machine are on do that and we will go from there
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
no this model isnt a big problem but they do have some issues but they all do i work on all name brands and the whirpool is the one i like the most
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal De
