Question about Dishwashers
Our Kenmore Ultra Wash Quiet Gaurd is not quiet. Could there be something wrong with it? Also, how long are the normal, pots & pans, and smart washes supposed to last? The model # is 16512200, Serial #FM3107487, stock #16512, and Type # is 575.0. Thank you for your assistances.
  • Dishwashers Master
  • 43,501 Answers
Everything you are asking is or can be relative. The noise issues is a matter of personal preference and what is quiet to someone else may not be to you...
Make sure that ALL parts were installed and installed correctly. If the blanket that often covers the dishwasher to absorb noise gets pushed off or bunched up the dishwasher can be very noisy. If the kickplate insulation is missing the appliance will be noisy. To check these parts the dishwasher may have to be pulled out, checked, and reinstalled.
The times also can be dependent on the loading, the amount of food on the dishes that you are washing and the water pressure of the water coming in to the dishwasher. without knowing all of these things I cannot give you an answer that could be taken and used with any reliability.
Speaking VERY generally I would expect the normal to last somewhere around and hour, the pots and pans to be 1.5 hours and the smart wash to last somewhere from and hour to two hours....that one is really variable!
I really hope that this gives you the info you are looking for and that it has helped you out!
heatman101
Posted on Oct 12, 2010
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Why my dishwasher wont start?
Sounds like you have a bad control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 27, 2014 | Kenmore Dishwasher With Ultra Wash And...
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
Jul 20, 2014 | Kenmore Dishwasher With Ultra Wash And...
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
