Question about Cell Phones
I have a panasonic pnlc100ya cordless telephone, when an outside line rings my number, the phone does not ring. Therefore, we missed a lot of calls. Please advise.
  • 490 Answers
SOURCE: missed calls
i voice mail setup.close the timings options...or chk in phone settings....
Posted on Oct 18, 2007
  • 316 Answers
SOURCE: problem with the number of rings
Remove the voicemail or extend ring time
don.t know is this code works world wide but you can try otherwise ask the provider to lengthen the ring time to 30 secs
then enter country code IE 61 for australia
* then vmail number IE 321 for optus
**30#
so your code should look something like this
**61*321**30#
then hit call.
remember the 61 and the 321 will vary on country and provider
Posted on Nov 09, 2007
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Posted on Feb 17, 2008
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
Supriyo DG
  • 58 Answers
SOURCE: I want my N73 to ring for longer than 2 rings
Hi
Set a FULL SONG from your archive as RING TONE. This will play longer time to remind you that someone is calling.
Thanks.
Supriyo DG
Posted on Jun 12, 2008
My panasonic home phone only rings once, it used to ring normally and would also say what number is calling. please help.
We recommend you unplug the Panasonic base unit and make a test call from another number. If the line disconnects after 1 ring then you have either a telephone line problem or another device connected to the telephone line is the problem.
Mar 03, 2014 | Panasonic (KX-TG1032S) Phone
No dial tone and "line in use " message
the wire that is used to connect the line to the telephone is not proper...
Mar 02, 2008 | Panasonic KX-TG6071M Cordless Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Will a panasonic KX-TG2257 cordless phone work with a KX-T6160 system?
    I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
    Carl
    Apr 30, 2011 | Panasonic KX-TG2257 Cordless Phone
    How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
    The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
    CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
    Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
    Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
    A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
    Carl
    Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
    Can't call out and Phone keeps ringing on in coming calls
    It was all in the outside phone lines. But thanks for the intrest.
    Dec 29, 2008 | Panasonic KX-TG1034S Phone
    Cell Phones Logo
    163 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
