Question about Dishwashers
I need a wiring diagram for my Jenn-air dishwasher
Jenn-air dishwasher dead
no lights on front door
I get voltage through door switch
I need a wiring diagram so I can trace circuit.
  • Anonymous Mar 26, 2014
    THERE ARE 4 SINGLE CONNECT WIRES AT THE MAIN PCB IN FRONT DOOR I NEED TO CONNECT THEM
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Posted on Jun 03, 2008
2007 escalade 2 front doors wont trigger dome light but rear 2 doors do? Also killing battery on vehicle, I suspect maybe radio stays on due to vehicle not knowing driver left vehicle.
Door ajar switches maybe bad . Take the door panel off ,find a wiring diagram an test the circuit . Or you could check at the BCM ,would still need wiring diagram so you know what wire is what . Do you know how to test electrical circuits using a DVOM - digital volt ohm meter ? Could also take it to a qualified repair shop an have the BCM checked for DTC'S - diagnostic trouble codes .
The BCM, the door switches, and the liftgate module (LGM) (if equipped with power liftgate) communicate through the GMLAN serial data circuit for the lamp illumination commands of the doors, liftgate, and liftglass open/ajar switch signals. The LGM receives a ground signal from the pawl switch, ratchet switch, and liftglass ajar switch that are located within the liftgate latch and liftglass latch. For all vehicles, the left and right rear door latch switches are both on one circuit that is also an input to the BCM.
If the vehicle has a manual liftgate, there is an input circuit from the liftgate latch switch and liftglass latch switch directly to the BCM.
The left and right front door courtesy lamps receive voltage and ground from the driver door switch and the passenger door switch respectively. The remaining courtesy lamps are controlled and receive voltage through the BCM from the CTSY fuse in the instrument panel fuse block.
DTC B2555 01: Passenger Compartment Lamp Control Circuit Short to Battery
DTC B2555 02: Passenger Compartment Lamp Control Circuit Short to Ground
Aug 07, 2017 | Cars & Trucks
I took the inside of the door off my Jenn Air dishwasher and now it won't start
You broke it!!!!!!! Check out the wiring associated with on/off cycle. There might also be a switch by the door designed to not allow unit to turn on when door is open - check it out. It might not be engaged if the inner panel of door is not properly hitting the switch.
Aug 22, 2017 | Jenn-Air 24 in. JDB1100AWS Built-in...
Headlights wont work
According to my wiring diagram, the headlight switch works a relay which is powered by two different fuses.
I would check the relay for voltage first.
You may need a repair manual to trace the circuits.
Dec 19, 2012 | 1991 Volvo 240
Jenn air dishwasher model JDB3610AWX has no power at the control board please help
Their are a couple possiblities that could be causing that;
1) the connections where the house wiring connects to the dishwasher in of the junction box has burnt, the circuit breaker will very likely be on but the bad/burnt connection wont send power to control.
2) one or both of the door switches on the latch asm. are bad,to check those use a meter set to a low ohms setting and check for ZERO ohms when the door is closed,to check those TURN OFF CIRCUIT BREAKER remove wires from switch(s) and place one meter lead on each terminal
I hope this will help you to figure out why your dishwasher won't come on,
Gene
Aug 06, 2011 | Jenn-Air Dishwashers
No lights in the screen,wont turn on anyting but
One thing to be sure of is that the unit is being supplied with power to the right areas. Try to (safely) trace the circut all the way from line voltage to the area where you want the load, say the heating coil or the display. Follow the wires from inlet to output, and see if any parts are recieving voltage that aren't responding. Also, be sure to check the door switch for ohms. Disconnect the power, and disconnect the door switch from its terminals. Measure with your Ohm meter to see if it opens and closes the circut when pressed. If it doesn't respond either way, then it is your problem.
Dec 17, 2009 | Jenn-Air Electric Double Oven
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Dec 10, 2008 | Frigidaire 24 in. FDBB540 Built-in...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Bosch Dishwasher SMU 2046
It doesn't work at all If your dishwasher doesn't work at all, check these:
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Oct 20, 2008 | Dishwashers
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Dishwashers Logo
185 people viewed this question
Top Dishwashers Experts
