Question about HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP PC (Intel Core 2 Duo T7500 2.20 GHz/4MB L2 Cache, 3GB RAM,... (RM922AAR1)
The laptop battery does not charge anymore. Can you please confirm if the below mentioned is the correct replacement battery, and also, where can I get the required battery in Zurich. Replacement battery id : 452057-001
Would like a circuit diagram for dell inspiron 1000 power circuit
There is a reverse polarity diode that prob popped. It doesn't allow the power to even reach the battery anymore. It'll prob charge in another laptop that takes that battery. The diode is on the mother board.
Nov 24, 2013 | Dell Inspiron 1000 Notebook
Cannot identify battery
This looks to be a long standing known problem for some models of Dell laptops with no magic cure that fixes all occurrences.
The remedies that have been suggested include:
1. Updating the BIOS (which you mention doing already)
2. Downgrading the BIOS to the lowest level - presumably to bypass changes that were introduced in later versions to give 'intelligence' to the battery and charging circuits and possibly prevent battery fires!
3. Having Dell replace the motherboard - assuming you have warranty cover or are prepared to pay to get this done.
4. Installing a new batter.
5. Buying a new charger of the correct capacity needed to charge the installed battery.
There is one further solution that is implicit but not mentioned - replace the laptop!
Dec 14, 2011 | Dell Inspiron 6000 Notebook
My kodak slice wont hold charge anymore. it works fine when its on the charger but when i take it off its dead. how can i fix this?
The battery is worn out , it is weak or has expired the life. so to confirm you need to take the battery out and ccheck the charge current, then put this for charging and recheck on the change of voltage. Now place on the camera and as the charge goes down check the voltage.This will indicate and confirm the battery.
Replace with the same type.
Jun 14, 2011 | Kodak EasyShare DX4530 Digital Camera
I have a acer 7520 aspire it charged but when pushing power button it wnt charge. Please help
This is a problem either with the charger or the battery.
Most probably a battery issue which will have to be replaced with a new one. The best solution is to take this laptop to the acer service center to confirm the problem.
You can get their contact details from the below link:
http://www.acer.com/worldwide/support/service.htm
Thank you!
May 03, 2011 | Acer Computers & Internet
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
Hp zd8000 laptop; new battery shows 100 percent charge, when I unplug power computer powers off and does not operate from the battery. Is there a setting that I need to set?
dear sir,
you didn't mention how long you are using this laptop, i mean that approxmite age of that laptop. problem you mentioned upper can happened for cause given below:-
1) if battery damaged.
2) if battery internal circuit out of order.
3) if battery internal one cell out of order.
open the battery case then if u have proper idea about AVO meter operation then u can check battery by measuring battery current (per cell) plz. then u can find out which battery is out of order, another think is u can check it by replacing saim battery unit.
thanks.
Dec 13, 2009 | HP Pavilion zd8000 Notebook
Battery not charging
The battery is probably dead. If the battery is two years or older, it may be time to replace the battery.
Also, if you have a voltmeter, confirm that the p/s is supplying you with the correct voltage.
Good luck
God Bless
-Carlos:
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Battery charging/laptop
The battery may be getting old/depleted OR some of the cells in the battery may be dead/malfunctioning.
The battery is probably still worth using for a while yet, though it will last a much shorter time than usual.
Alternatively, you could get a new replacement battery.
A remote possibility is that you are using a wrong charger for the laptop - it does not supply enough power to the battery. Please confirm it is correctly rated.
All the best!
Jan 30, 2009 | Computers & Internet
My laptop wont charge
If your laptop isn't charging, it's usually one of two problems:
1) Your AC adaptor isn't working correctly anymore. It may be faulty, or may simply have endured all the wear and tear it can handle.
2) Your battery is either dead or dying, and is no longer charging correctly.
If the problem is your AC adaptor, a simple replacement will fix the issue. If the problem is your battery, then it gets a little more expensive (batteries usually aren't cheap).
Most laptops come with software to help monitor battery life and so on. Dell, for example, have their "Quickset" software, which can tell you if your battery is operating properly or not.
If you give me more details on the specifics of your laptop, I can help more. Manufacturer/Model?
Hope that helps.
Jan 16, 2009 | Computers & Internet
My Toshiba Satellie P15-S470 turned off by itself and I can not mak it to run.
Sir:
Is your laptop connected to a power source? If not it needs to be recharged...
Check also the battery of your laptop, it might be dead already... meaning even if it is charging the battery doesn't charge anymore... it may need replacement.
To check the battery... remove it from the laptop and find a flat button to check if the battery is charged, or half charge, or none at all. If below half then the battery needs to be replaced.
Jan 23, 2008 | Toshiba Satellite P15-S470 PC Notebook
Open Questions:
See all HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP PC Questions
HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP PC (Intel Core 2 Duo T7500 2.20 GHz/4MB L2 Cache, 3GB RAM,... (RM922AAR1) Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
