Question about Zoom H4 Handy Recorder
Doesn't turn on - Zoom H4 Handy Recorder
  • 2 more comments
  • rjvenicefl Oct 13, 2010
    Thanks, I've tried 2 sets of new batteries, tried plugging it in with the adaptor in an outlet that I tested works. I hadn't used it in several months, sitting on a shelf, but don't remember it falling or something like that. It used to turno on just fine
    what was that?
    Just wondering if this is the opinion of others, the device has failed
    well I took the batteries out, and then with adaptor it turned on (wouldn't turn on with batteries in) but won't do anything else. If I hit record it turns off. If I turn it off won't come back on for a few minutes after unplugging it. It worked so nicely a few months ago!
    Genius:
  • 1,035 Answers
Hi. Have you tried running the recorder using AC adapter. This is a common issue with this recorder. Did you noticed that the batteries became hot when you plugged it in the device? If yes, then you need to have the unit checked with the manufacturer and have i repaired. Do not attempt to turn on the unit or put batteries to avoid further damage.
Posted on Oct 13, 2010
  • Angelito Rabago
    Angelito Rabago Oct 13, 2010
    This is already a unit problem. You should be able to use the unit when using an adapter. Since it wont let you do that, then there might be something inside that is not functioning well. Might be one of the chips is failing. i suggest you take it to the store where your bought it. I hope it is still under warranty.
    Top Expert:
  • Zoom Master
  • 79,865 Answers
Are the batteries defective?
  • 1 more comment
  • yadayada
    yadayada Oct 13, 2010
    add
  • yadayada
    Then the device has failed, the cost to repair is more than the cost to replace.
  • yadayada
    yes
2004 Ford Taurus won't start?
get your battery checked
May 27, 2013 | 2004 Ford Taurus
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Sep 27, 2012 | Televison & Video
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2002 Dodge Caravan,3.3L,Engine won't turn over at the key.Battery,starter and relay are good.Relay doesn't function when plugged in.It has 2 feeds.If you run a ground to the ground side of the...
It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
Mar 04, 2018 | 2001 Dodge Grand Caravan
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Jul 19, 2011 | Canon IR1018J Black and White Copier
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
My 1993 corvette wont start
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
Nov 11, 2010 | 1993 Chevrolet Corvette
Zoom H4 Handy Recorder Logo
159 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
