Question about Stanley Bostitch Rn461 Gun Coil Roofing Nailer
My plunger will not reset - Stanley Bostitch Rn461 Gun Coil Roofing Nailer
    Scholar:
  • 70 Answers
Hi There,
The most popular way of re-setting the driver to top dead centre is to take the nails out of the tool, find a peice of scrap timber, make sure that the air is not connected to the airline at this time then, put the tool onto the timber as though you're going to use it. Push the nose down & pull the trigger. While ayou are doing this re connect the airline to the tool. This should correct the problem.
Usually, this will happen to any make of tool. It is just a fact of life & now way is a bad mark against the brand!
Good Luck!
Posted on Oct 16, 2012
Changed battery on Accurist BJ3547 as hands stopped though digital signal was still OK. New battery installed, digital signal still OK but hands still don't move . A video said a reset req'd, How?
  1. The "AC "or "All Clear Circuit" button if the watch has one will be found on the back of the movement. It will usually be a small silver or gold dot marked "AC" or reset. In some cases it will be a small hole or plunger you depress with a pin punch.
  2. Clear watch memory. Look for and find the small gold or silver dot on the back of the Seiko watches movement. It will be marked "AC" if it exists. Use the metal tweezers and touch the "AC" button with one prong and the battery with the other. In some cases you just push in the plunger on the "AC" button. In the case of a plunger or hole press it with a pin punch.
Aug 14, 2016 | Accurist Watches
Location of reset button on Series E vacuum
This item.. Switch Interlock is activated by Interlock Plunger that is under the Rainbow. The water pan has a plastic mold on top that pushing into the Interlock Plunger. If the plastic mold on the water pan is broken, then the Rainbow will not run. We are here if you need further assistance....Contact Us
RainVac
Jul 15, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Carb floods fuel to airbox
The float is not closing the plunger. reset the float flap so that it pushes the plunger up into the carb seat, When the float is at it highes point, there should be no fuel comming through. If there is reset the flap a bit, by turning it up a bit. With a pair of needle nose pliars ( be gentle). You don't what to break it from the float. (When the float is at its highesd position, you should not get anything comming out from the plunger). If you still get leakage check the plunger seat. and tip. It might be dirty or worn.
:Jerry
Jun 18, 2011 | Honda VTX1300S Motorcycles
1990 Ford Escort xl fuel reset button location.
this button is located in the rear of the vehicle inside the trunk behind the interior trim either on the right or left side.it is a small black box and will have a small plunger on top.this plunger will be in a down position and you will have to pull the plunger up and it should stay up,
Mar 11, 2011 | Ford Escort Cars & Trucks
Timing chain tensioner reset
ON EARLY MODELS BEND A PIECE OF HEAVY WIRE INTO U SHAPE APPLY LIGHT FORCE ON TENSIONER SHOE TO COMPRESS THE PLUNGER.INSERT A SMALL SCREW DRIVER INTO RESET ACCESS HOLE AND PRY THE RATCHET PAWL AWAY FROM THE RATCHET TEETH.THEN INSTALL THE LOCKING WIRE OR KEEPER INTO THE ACCESS HOLE AND SHOE.ON THE LATE MODELS IMSTALL TENSIONER UP SIDE DOWN AND COMPRESS THE TENSIONER PLUNGER ON A FLAT SURFACE UNTIL ALL THE OIL HAS BEEN PURGEDFROM THE TENSIONER AND PLUNGER LOCKS INTO PLACE OF TENSIONER BODY.
Feb 22, 2010 | 1999 Oldsmobile Alero
Message service apears on instrument panel
If the light says SERVICE only it is simply a servide reminder light and will go out after approx. two minutes. You should be able to reset it by removing a small black rubber plug on the face of the insturment cluster. under the plug is a small black plunger. Push down on the plunger with a pen until it clicks.
If there is no plug look for a small black button (not the odometer reset button) about 3mm in diameter. Push the plunger down and it will reset.
Hope this helps.
Feb 27, 2009 | 1990 Volvo 740
1988 toyota corolla sr-5
Locate the brake switch up above the brake pedal. Push in on plunger and check if brake lights go out. This switch can be unplugged and removed from its spot at the pedal. Then you can pull out plunger and reset it, put back in its spot, and let pedal readjust to the appropriate travel. It should automatically set to correct stroke length after pulling plunger outward to its furthest length. If this switch, or its adjustment is not to blame, post again. I will help more if needed.
Thanks, I hope this helps. TT
Jan 29, 2009 | 1988 Toyota Corolla 4 Door
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Jun 22, 2008 | Timex Expedition 40141 Wristwatch
All Pro SPC85
what you mean "plunger?" the reset button?
Jan 05, 2008 | All-Pro SPC-85 Utility Heater
Batteries out
You can reset it with holding [SF] + [M1] ( the big button with denso on it) +[0]+[PW] simultaniously
WARNING it will clear all existing programs running on it.
After you reset it you should be able to upload new software on it
May 10, 2007 | Denso Nippondenso BHT3000 (bht3041)...
Stanley Bostitch Rn461 Gun Coil Roofing Nailer Logo
201 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
