Cannot log on at all on my acer laptop can anyone help?
    Scholar:
  • 139 Answers
I assume u r using winxp.
As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by
a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands.
And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with
Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repai...
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your
sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or
wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the
initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it
should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press
R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a
progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically
with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT
+ F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the
Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on
without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without
being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the
Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use
one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for
example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after
making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new
password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a
Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set
a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything.
This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new
password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and
follow the wizard which will let you choose a new password to use for your account. Just in case your laptop isn't set to boot
from cd, it probably is, you just have to go into the BIOS and make sure sure that the cd is is set to bootable and it is set
to boot from cd before your hard drive. Try it with your Win XP cd first and if it doesn't work and you don't know how to go
into the bios and set it, add another comment and I'll come back and tell you how to do that. This looks long and involved but
it doesn't really take that long.
hope this works
thanks
Posted on Jun 01, 2008
"2 MIN" icon on log in screen
Is you laptop works fine, and what icon do you mean and where it appears?
Dec 06, 2012 | Acer Computers & Internet
I cant format my acer aspire 5315, have to fomat it becouse my compute wont log into windows becouse a saystem driver is missing or hurt. Can anyone please help me so i can re install wimdows vista basic?...
yes you need to format, you need the cd for do this, download with another compuiter and use your key password, look under the laptop the key number is your licence
Aug 04, 2010 | Acer Aspire 5315 Notebook
No internet access on my Acer Aspire
Sorry don't have the solution to this problem but the same thing happened to me around the same date with my Acer netbook.
Good Luck
May 27, 2010 | Acer Aspire One PC Notebook
My Friend Has a acer laptop He can not get passed
1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
2. Power the system on.
3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
4. At the eRecovery Management menu it will ask you how to restore.
5. Click on the restore option you would like to use.
Regards.
Jan 15, 2010 | Acer Aspire 3680 Laptop
I installed Norton 360 on my computer then later shut it down for the night. The next morning when I awoke I turned on my computer and now it won't get past the Windows XP log in page. I click to log in...
Hello. Call Acer and have their support tech talk you through the necessary fix Since your lap top is new it will be under warranty so they will help you for free. Regards, Joe
Dec 18, 2009 | Acer Aspire 5000 Notebook
ACER 5720 travelmate hangs then reboots on agpCPQ.sys
sony viao laptop starts to log on after entering password then shuts down.
May 11, 2009 | Acer Aspire 5720-6661 Notebook PC
My user password on a acer
Restart the computer pressing the "F8" key. When a list comes up choose "Start in safe mode". Log in as the administrator. Go to the control panel and choose "User Accounts" then click your username and hit change password.
Mar 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can not log in
The Manual if you have one or Acers Tech Help site is where you will get help
May 13, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
