Question about SVA-USA HD4208UII 42 in. HDTV-Ready Plasma Television
My tv does not come on on less i use the reset button on the back of the tv whats the problem
32LX1D lcd that has great sound but no picture at all. I tried all of the inputs but no luck. It's an older tv but the picture was great on it before it went out. I haven't seen any blown capacitors o
have yo tried resetting the picture . there usually is a reset button on the tv.;s in the back of it. Or try resetting the contrast and lighting
on the tv. sometimes those get turned wrong and it will look as if there is no picture. if all else fails either take it to a repair shop or if you can purchase another one. The tv;s are fairly inexpensive now
I have seen them on sale for 250.00 dollars and less especially if
you purchase it from the internet
Jan 18, 2013 | Televison & Video
I hav ethe akai model number pdp4295ed and the color is very bad on the screen. how can i adjust it? it was a power outage one day and the tv came back on this way.
U have the tv original remote wright?Yes?Push the tv remote button that said Menu.Go into the tv Menu at already or goto PICTURE than go down to do a resetting than everything will return itself back to the factory setting and now just go to the Colors Setting lower -30 less than the colors on the tv now ur tv should be good and have a correct pictures coloring.
Aug 29, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
My sony trinitron tv wont turn on. it blinks 4 times on standby. what do i do
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Aug 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sound on the TV just went about a week ago and i cannont get it back for some reason. Everything else is perfect so I dont know what is wrong with it?
Check your TV may be set to Auto SAP in the MTS feature. Make sure the speaker option is set to On in the Audio Menu. Or Reset in Factory setting> Turn on the TV. While holding down the RESET button on the remote control, press the POWER button on the TV front panel.The TV will turn itself off, then back on again. Release the RESET button.
Jun 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Toshiba TP61F80, i have had the tv for little less than a year. It is a GREAT tv I love it. My tv is plugged into my home stereo so when i power that on tv turns on as well. I pushed the power...
Try unplugging the unit for 10 minutes, then plug back in and try it. If the unit just has a fault this will reset it and it should work. If it does not solve your problem I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains the troubleshooting process and should help you isolate the problem. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 21, 2010 | Toshiba TP61F80 61 in. Rear Projection...
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
SVA-USA HD4208UII 42 in. HDTV-Ready Plasma Television Logo
27 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
