Question about Sony XR-M510 Cassette Player
Every time I take the key out the ignition it turns off but when I turn the car on again I have to enter the code why is this??
    Scholar:
  • 50 Answers
Hello, It sounds as if when the unit was installed the installer installed the power constant lead to the ignition. This will make the stereo think that it has been removed from the car and puts it into security mode causing you to have to enter the code to make it work. If you don't know how to do this repair any car audio shop can fix this cheaply. If you know about car audio wiring verify that the constant battery wire is going to the 12+ constant lead in the fuse box and the ignition lead from the radio is going to the switched ACC lead in the fuse box. Also check the fuse behind the radio and make sure it is not loose or blown. Voila it should be fixed. If not check the manual that came with the radio and make sure their is not a setting that requires you to enter a code each time you turn it on, not many stereos have this feature but yours may. If you don't have the manual Google it and you can download it for free.
Posted on Oct 12, 2010
How do i reset my becker juke box radio be2233 from wait to code?
You must leave the radio turned on and most importantly the key must be in the ignition turned to the first point that turns acessories on.
You may have to wait for up to 2 hours before the radio returns to code and the power must not be interrupted during this time or the wait period will start all over again. Obviously make sure your car is in a safe place whilst you are waiting as key must be left turned in ignition.
When you get code back on the display you can enter your code as normal. If you do not have the correct code for your radio send your enquiry here and they will sort it out for you.
Thanks for using FixYa.
Aug 10, 2011 | Car Audio & Video
How do you change the keyless entry code
You need to key in the original key code, then within 5 seconds press 1/2 button. Key in your new code, then the door locks should cycle to indicate the code has been saved.
Aug 12, 2010 | 2002 Ford Explorer
Have a code alarm for car remote dont work and cant disable it. wont start how do i disconect alarm so car will start
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Aug 03, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
How do you re-program the security code on a 2007
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed. (MAYBE)
KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-Some vehicles use 5 turns of the key instead of 8
Jun 05, 2010 | 2007 Ford Explorer Eddie Bauer
How can i program my door lock code or find out what it is. on my 2000 limited edition explorer
FORD KEY PADS
FORD KEY PADS/REMOTES
NOTE-I found that some Explorer/Mountaineers enter program mode after 5 times-not 8.
Here is the link for further info.
http://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Your factory code is on a card in the owners manual. If that is lost, access the control module in the cargo area behind the left cover panel.
You MIGHT be able to see the code printed on it, or you might need to pull it out in order to see it.
May 27, 2010 | 2002 Ford Explorer
Error message on my ford radio
Yes - there is a solution here.
The problem here is that you must leave continuous power to the radio. Any interruption causes the countdown or wait period to start all over again. The secret is to ensure the key is turned in the ignition to accessories point I or the first point on the ignition that activates power to the radio.
If the key is not turned in the ignition as outlined, the radio will automatically shut off after one hour which is a power saving feature (which is great) but it also has a side effect in this case of shutting off the radio before the time limit has been reached!!
Obviously - as you must leave the key turned in the ignition during the wait period (which may be up to 4 hours) please ensure the vehicle is parked in a safe location and well away from any opportunistic thief.!!
Hope it helps or for anyone reading this in a similar situation - this information applies to many vehicles and radio types as many manufacturers have a similar security feature - not just Ford.
Thanks for using FixYa,
Nov 21, 2009 | 2003 Ford Expedition
Immobiliser is not turning off and not allowing the engine to start
is it a stick immobiliser?
If your vehicle does not start and the LED continues to flash while the Ignition is 'ON', this means that the Immobiliser system has not recognised the transponder stick.
Simply turn the Ignition 'OFF' then back 'ON' again. If the Status LED continues to flash, move the transponder stick closer to the key barrel until the LED stops flashing and turns 'OFF'.
If the transponder stick on the key ring does not disarm the immobiliser or the
transponder stick is misplaced, you can override the system by entering a 5-digit override number. Each vehicle has a unique 5-digit override number. This number is recorded on the
customer’s owner’s manual. If the customer loses their owner’s manual / override number, the number can be found by locating the vehicle’s Daewoo Stock Number (D.S.N). The customers override number is the last 5 digits of their D.S.N.
Overriding the system using the example 5 digit code 2,1,0,6,2
Important Note: 10 flashes of the Status LED represent the number ‘0’.
1. Remove the Transponder from the Key Ring.
2. With the system armed (LED flashing slowly) Turn the ignition ON/OFF 5 times, with the final position being off.
3. The LED will turn solid red for 2 seconds and then begin to flash.
4. When the LED flashes twice (2), turn the ignition ON. (number 2 was entered)
5. Turn the ignition OFF and wait for the LED to flash once (1) and then turn the ignition ON. (number 1 was entered)
6. Turn the ignition OFF and wait for the LED to flash ten (10) times and then turn the ignition ON. (number 0 was entered)
7. Turn the ignition OFF and wait for the LED to flash six (6) times and then turn the ignition ON. (number 6 was entered)
8. Turn the ignition OFF and wait for the LED to twice (2) and then turn the ignition ON.(number 2 was entered) The LED will turn solid red, which means the system is now overridden and the vehicle can be started. If an incorrect number is entered in, wait 11 flashes then start the procedure again.
NOTE: This is a one-event override. Once the ignition is turned off, the vehicle will passively immobilise after 30 seconds. If your 5 digit override number does not override the system, the chances are that you entered the wrong number. If this is the case, you’ll need to re-enter the override number
and try it again.
Jul 13, 2009 | 1999 Daewoo Lanos
How to reset the raido
There is a trick to the procedure. You have to turn the key to position 1 or the first stop on the ignition. Turn on the radio and wait between 2.0 to 3.0 hours for the radio to reset and ask for the code. From the owners manual. My 97 takes between 2:25 and 2.5 hours to reset. Every radio is different.
To enter the code:
After installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I
the unit must be turned on
Make sure the headlights are turned off to help prevent battery drain (please refer to page 2:6 for information on turning the headlights off). Enter the code again once this time has elapsed.
Ryan
Jun 11, 2009 | 1994 Volvo 960
My honda cbr 600rr 2005 will not start the hiss system is flashing when key is in ignition ,and when you turn the engine over it just will not fire up help
1. Obtain a new transponder key.
2. Grind the key in accordance with the shape of the original key.
3. Apply 12V battery voltage to the ignition pulse generator lines of the engine control module (ECM).
4. Turn the ignition switch ON with the original key. The immobilizer indicator comes on and it remains on.
*The code of the original key is recognized by the ECM.
*If there is any problem in the immobilizer system, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-5).
5. Disconnect the red clip of the inspection adepter from the battery positive (+) terminal for two seconds or more, then connect it again. The indicator remains on for approx. two seconds, then it blinks four times repeatedly.
*The immobilizer system (HISS) enters the registration mode. Registrations of all key except the original key inserted in the ignition switch are canceled. (Registration of the lost key or spare key is canceled.)
NOTE:
The spare key must be registered again.
6. Turn the ignition switch OFF and remove the key.
7. Turn the ignition switch ON with a new key or the spare key. (Never use the key registered in previous step.) The indicator comes on for two seconds, then it blinks four times repeatedly.
*The new key or spare key is registered in the ECM.
*If there is any problem in the registration, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-6).
CAUTION:
Keep the other transponder key away from the immobilizer receiver more than 50mm (2.0 in).
8. Repeat the steps 6 and 7 when you continuously register the other new key.
NOTE:
The ECM can store up to four key codes. (The four keys can be registered.)
9. Turn the ignition switch OFF, remove the inspection adapter and connect the ignition pulse generator connector.
10. Turn the ignition ON with the registered key.
*The immobilizer system (HISS) returns to the normal mode.
11. Check that the engine can be started using all registered key.
If that doesn't work,You will need to go to a dealer and have the keys reprogrammed.
Jun 04, 2009 | 2005 Honda CBR 600 RR
My Theft Lock is stuck on and now it is in InOP stage
I suffered the same problem. Turn your ignition key to the ON position for 1 hour. This will reset the double lock feature on the radio to prevent theft. Once you leave your ignition key on for 1 hour, turn the key to the off position. Remove the key. Then turn the ignition key back to the ON position. You should then see "LOC" instead of "InOp". Then try the steps to enter your code again. Three incorrect tries will enable the double lock feature again, and you will have to repeat these steps to reset it.
Mar 24, 2009 | 1998 Pontiac Grand Prix
Sony XR-M510 Cassette Player Logo
73 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
