Question about AEG L16820 Front Load Washer
Shows code E20, what does that mean? - AEG L16820 Front Load Washer
  • 44 Answers
From the manual, available here:
http://www.serviceforce.co.uk/pdfs/U26183.pdf
E20: problem with water draining
Try emptying the drain filter, normally at the bottom of the washer
Posted on Oct 12, 2010
  • 4 more comments
  • nicolapurdy Oct 12, 2010
    How do I empty it first though as it wont drain? Is it just a case of lots of towels on the floor..?!
  • Bobbinz Oct 13, 2010
    If the filter is blocked then I'm afraid so. If you find where the filter is (normally bottom of washer front) and open it slowly, you may be able to catch the water in a shallow container. good luck
    Further to my last reply, it appears that this model has an emergency drain hose next to the filter cap, so you should be able to drain the water into a suitable container.
  • nicolapurdy Oct 13, 2010
    Thank you so far! Ok, emptied the water, took the filter out, looks totally fine. Tried the cycle again, flashed up E40 this time, retried, said E20 again... What next?!
    Ah, just saw the manual link (thank you!) so E40 is door open... What do I check next as the filter looks normal?
    Well it sounds like either there is a blockage somewhere else, or the pump isn't working. Can you get to the drain pipe at the back, and check if there is a blockage there (i.e. full of water)
    If you empty the water from the washer, are you able to put the machine into spin dry mode? If so, can you hear the pump trying to pump water out?
3 Suggested Answers
  • 208 Answers
SOURCE: I have a code E20
bad pump
Posted on Jun 22, 2009
Daniel S
  • 4323 Answers
SOURCE: what does e20 mean?
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Posted on Jul 31, 2010
My machine comes up E20 towards end of program what does this mean
Really need the make and model of your machine as different manufacturers use the same code to mean diferent things. Hotpoint/Indesit/Creda generally use E20 to mean there is a problem with temperature sensing (Which generally indicated that the water heater element has failed. Zanissu/AEG Lavmat use E20 to indicate that the empty pump is blocked (Usually behind a kick plate at the bottom of the machine or a flip open door, you will find a cover that looks a little like a fuel cap). AEG also use E20 to indicate a door lock fault on some models. Personally, the fact that it is near the end of the cycle would indicate to me you have a blocked empty pump
Sep 26, 2015 | Washing Machines
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
I have an e20 error code on my 1990 cadillac sedan deville. What does that mean?
E20 means open fuel pump circuit could be failed fuel pump relay
Aug 18, 2010 | 1990 Cadillac Deville
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG L16820 Front Load Washer Logo
343 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
