Question about Kenmore 15864/15862 Top Load Washer
When i close the led hard it works why? - Kenmore 15864/15862 Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the machine will neither wash nor drain/spin unless you "slam" the lid, the problem points to a loose / damaged Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Oct 12, 2010
Won't turn on,Front led on,fans OK,and RJ45 led on.
fan working? cd rom drawer open and close? power on led working. hard drive spinning?
Oct 09, 2016 | IBM Lenovo ThinkCentre® M51 (814339U) PC...
Led screen dosn't work connected to external monitor will work as long as the led is almost closed
No reformatting will help . Unplug LED screen vga from board and see if laptop will work on external screen . Could be magnet switch .
Jun 08, 2014 | Dell Latitude E5500 Laptop
How to plug in led lights in a water fountain
never seen one but if you look really hard im sure you will find the plug in it is most likley close to the power inlet these lights run off dc power converted from ac power there is a driver somewhere that has the plug in
May 29, 2012 | Home
Is there such a thing as buying infrared Sensors for a TV having problems trying to buy one
Most likely the problem is with the remote. The infrared LED transmitter in the remote could be weak. If the remote only works when it is close to the TV then it is faulty.
Try replacing the batteries first, the maybe flat.
When you replace them and you still have trouble operating the TV and it only works at close range then you can purchase an infrared LED transmitter form an electronics parts store and replace the this LED in the remote.
NOTE the LED is a polarised device and only work if inserted correctly.
The LED will have a small flat surface on the rim of the LED next to the shorter leg wire is the K (cathode) - lead, the longer leg wire is the A (anode) + lead. Make sure it is fitted to the circuit board the right way around before you solder the LED to the circuit board.
Apr 03, 2012 | Televison & Video
Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
Dec 20, 2011 | liftmaster Chamberlain Garage Door Opener...
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Apr 27, 2009 | Foxconn Computers & Internet
How to connect the led wires in motherboard
hi use the motherboard manual for this and find front panal connector on motherboard
pin no. 1,3 is for hdd dark color wire is 1 anothee is 3 (hd)
pin no. 2,4 is for power led dark color wire is 2 another is 4 (p_led)
pin no. 5,7 is reset you can connect both side (rst)
pin no. 6,8 is for power on power sw (psw)
most of motherboard folow this diagram
Aug 15, 2008 | Intel Motherboard
Kenmore 15864/15862 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
