Question about Motorola TalkAbout T5000 2-Way Radio
How do I get the noise made after a transmission turned off?
    Sergeant:
  • 270 Answers
You are talking about the beeps after the transmissions... This is to indicate to the other unit that the TX line is clear. It is the electronic equivalent of say OVER when talking on a one way radio.
I am not aware of any method to remove this feature. Yet.
Posted on Oct 12, 2010
Is there a bearing or bushing on the shaft that the left axle slides onto on a 1999 Bonneville se?
i have been fooled by this one way to many times. when a wheel bearing or hub assesembly is making noise, it will sound like it is comming from the other side. i do not know why this is. but one test will prove if and which one. when growling noise occurs, notice, when turning left or right, does noise get louder and quieter as you turn? if so then it is wheel bearing. when turning left the right side will make more noise. when turning right the left side will make more noise. if always the same then, tires or transmission need addressing. the cv axle does not make a growling noise, unless front wheel drive car does not move, it makes a clicking or poping noise. sorry but at least you dont have to replace other axle
Sep 12, 2014 | 1999 Pontiac Bonneville
Clicking noise from transmission when taking right turn or sitting with driver side down hill
could be the steering box or gear... check there for the noise. You really can't tell where noise comes from from inside a car. They can be very transient
Mar 30, 2014 | 2001 Pontiac Grand Prix
Cobra microtalk pr165
Set the squelch control just until you no longer hear noise after a transmission ends. Increase the setting in small increments. Too much and you won't hear desired transmissions, not enough and you'll still get noise.
Sep 20, 2013 | Cobra Radio Communications
Transmission buzzing
Click this link below to troubleshoot the buzzing noise problem from transmission:---http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
--------This will help.Thanks.
Feb 19, 2012 | 1999 Toyota Camry
My 1995 Geo Prizm. I hear noise at the left side of the transmission where the drive axle enter the transmission not the usual clicking sound when the drive axle goes bad. The noise show up when I...
I would still suspect the drive axle because it could very well be the inner joint of the axle clicking and not making the accustomed noises related to a drive shaft noise.Thanks Megabuck
Aug 29, 2011 | 1995 Geo Prizm
My 2005 ford focus making screeching noise!
Serpentine belt , idler pulley bearing?
Jan 24, 2010 | 2005 Ford Focus
The manual transmission seems noisy so I wanted to replace the fluids or at least add some Z-Max to try and quiet the noise. I cannot find the add and drain plugs anywhere. There must be a way to do this!
Condition: Some customers may comment on a grinding or rattle type noise coming from the transmission. The noise usually occurs with the transmission in first or second gear at low RPMs and can be intermittent.
Cause: This condition may be originated by the natural harmonics of the engine that leads to a vibration in the transmission.
Correction: There are two separate noises. Follow the diagnostic procedures listed below to determine which noise the vehicle has and perform the outlined repair. If you are comparing like vehicles, you must compare vehicles with the same motor and similar mileage.
Diagnosis for Noise #1
This is a very distinct noise that is usually much louder than the second noise that can be associated with this transmission. If the vehicle is not making any noise when trying to verify the condition, it can be induced by making several tight left hand circles with the vehicle at normal operating temperature.
Making a sharp right hand turn will usually stop the noise. While the noise is occurring, in order to
distinguish between the two noises, you can press lightly on the clutch pedal without releasing the clutch and the noise will NOT go away or change. As a second diagnostic aid, while the vehicle is making the noise, shift to third gear and the noise will stop. If the noise is determined to be this type, perform the repair for noise #1.
Repair for Noise #1.. Replace the transmission fluid with Saturn Manual Transmission Lubricant, P/N 21018899. Overfill to a capacity of 2.4L (2.6 qts). A possible side effect of this repair may be a higher shift effort.
Solution #2 Capacity of 2.4L (2.6 qts). A possible side effect of this repair may be a higher shift effort.
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information
sub-section of the appropriate Service Manual.
2. Place a suitable container under the transmission assembly.
3. Remove the drain plug located on the bottom of the transmission and completely drain the fluid.
4. Re-install the drain plug. Tighten the drain plug to 38N·m (28 lb ft).
5. Lower the vehicle.
6. Remove the fill plug located on the top/middle of transmission on the driver side, near the red
vent cap. If you use the check level plug on the side of the transmission, you will not be able to
overfill the transmission.
Important: Fill the transmission to the amount specified. Too much lubricant will cause the fluid
to leak from the vent. Not enough fluid will defeat the purpose of this bulletin.
7. Fill the transmission with 2.4L (2.6 qts) of Saturn Manual Transmission Lubricant P/N 21018899.
DO NOT USE THE RED VENT CAP TO FILL.
8. Re-install the fill plug. Tighten the fill plug to 38 N·m(28 lb ft).
Diagnosis for Noise #2
This noise, commonly referred to as gear rattle, can be induced by lugging the engine in any gear, but is
usually most noticeable in first or second gear. While the noise is occurring, if you press lightly on the clutch pedal without releasing the clutch, the noise will be reduced or eliminated.
Repair for Noise #2
Do not attempt to repair this noise. This is a characteristic of the vehicle and any vehicle equipped with a manual transmission can be made to make a similar noise. Driving at slightly higher engine RPM levels will reduce this noise.
Oct 03, 2009 | 2001 Saturn L-Series
Car make noise, look like is left wheel bearing or transmission. When turn right noise dissapear. When car is risen on stands , noise only when left wheel is turning. It is wheel bearing or transmission...
Check the CV joint that the axle connects to. They make a clicking sound when turning a corner if badly worn. Both CV joints are commonly replaced when one of them goes out.
Sep 08, 2009 | 2002 Mazda Protege
Binding on turns from transmission
Check the axels.. Could be a bad knuckle in the axel shafts on the front.. That would explain why it makes the noise only in the turns.
Jul 06, 2009 | 1995 Subaru Legacy
Motorola TalkAbout T5000 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
