Question about Hitachi 53UWX10B 53" Rear Projection Television
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. Please give me an answer to what is wrong. Thank you
  • Hitachi Master
  • 8,457 Answers
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 12, 2010
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The color has separated, I have a purple and green shadow around all objects
U know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com for the convergence kit to repair ur self.The shop will cost u $300 for the parts and labors.
Oct 22, 2009 | Philips 46PP9302 46" Rear Projection...
Purple and green strip/shadow around all the images and at the bottom
Either a bad optical block or possibly a bad LVDS cable, you need a qualified tech to know for sure
Sep 19, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
Double shadow green and pourple
check the 3.3ohm resistors right next to the convergence ICs. Also the ICs for 3.49 are most likely cheap chinese ICs and not origional sanyo ICs . I have seen the cheap ICs go out as soon as you power up the set the first time.If you need more assistance please let me know.
May 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
Oct 21, 2007 | Mitsubishi WS-55807 TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
95 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
