Sony kv 29x5d
This SONY KV 29X5D tv turned off itself and some burning smell in the room.I disconnected it , opened back cover and found that on the primary power supply section a ceramic capacitor marked as C633 was cooked, i took it out - its not possible to read its FARAD and VOLTAGE value ...to replace it with a new one .Its a PAL TV 240V powered.
Please can you help me ,thanx .
  • pantelis th Jun 02, 2008
    THIS IS THE MODEL : KV 29X5D ( It's for Europe )
  • 10,594 Answers
Please mention correct model number to check C633 value.
My system recognise this model as incorrect.
Posted on Jun 01, 2008
  • Shahid Electronics
    Shahid Electronics Jun 03, 2008
    Sorry mate, I dont have info for Euro models.
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-35XBR48 has a burn smell, won't turn on. Work fine the day before. Power supply? Thanks
yes. has a power suplly kit. common problem. consists of two transistors two resistors, and thermistors. its called a sony service kit
Nov 17, 2009 | Sony KV-35XBR48 35" TV
My tv smells like it's burning
Remove the back cover and look for discolored components(most likely coil or transfo),also unplug teh set after it has warmed up and touch components lightly to feel for overheating.i had burned coil in a similar set,around the pincushion circuit. good luck
Oct 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My tv turned itself off this morning, then when i tried turning it back on, its making a buzzing sound, and i can smell burning, any ideas? its not turning on still, just the red standby lights on.
i have forgotten my parental control pin after five times pin then it has blocked how to unblock it. which codes should i use to unblock
Jun 29, 2009 | Sony KV-27V22 TV
SONY KV 29X5D
Thats great buddy. have nice day!
Jun 04, 2008 | Televison & Video
Sony KV32HS420
Good day.
I believe there may have been some parts that were burned out due to high voltage. There are cases where insects such as lizards penetrated and got stuck then got stuck then got electrecuted inside. You can open the back cover of your unit or better, refer to the repairman.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV-32FS13 No Power.. No nothing
has a power supply or deflection fault requires service
Mar 16, 2008 | Sony KV-32FS13 TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Double images on my Sony FD Trinitron WEGA KV-27FS100
You may want to try disconnecting the power for about 30 seconds and rechecking the TV. Otherwise, it may not be worthwhile repairing.
May 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
384 people viewed this question
Top Televison & Video Experts
