What is the difference between a wireless access point and wireless router?
    President:
  • 2,777 Answers
To have an access point you need some kind of routed on your network already. For most home users they just add a wireless access point if they have an older router that does not have built in wireless. If you do not have a router already, you want a wireless router for sure.
For businesses they buy multiple access points to extend the range of their wireless networks. They still need a router, which would not be wireless in most cases, it would be a commercial grade router. Then they have access points all over the building (or buildings) where they need wireless access.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 12, 2010
We have a router so that we can have wireless connections in the upstairs of our house. The connection shuts off every 20 min or so. Do you know a solution?
Have you tried moving the computer upstairs to a different place to get the best signal ?
What is the signal strenth?
Have you tried moving the router to a different position?
If your signal strength is quite weak, you may need to get a more powerfull router, like this one http://bestofferbuy.com/2.4GHz-1000mW-High-Power-802.11b/g-WLAN/WiFi/Wireless-Broadband-Router-p-50909.html?currency=GBP&utm_source=gbase&utm_medium=cse&utm_campaign=gbase
they are about twice as expensive.
Oct 16, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
Wireless continually goes off and on (I mean connects and disconnects). The signal is strong, but the laptop keeps disconnecting.
The cause could be any of the following:
  • Interference. Many other wireless devices operate near the same frequency. In the US, there are 11 different channels. Try selecting a different channel and see if that helps.
  • Your wireless adapter driver maybe out dated. Check to see if there is an update.
  • Either the wireless adapter or the wireless router / access point is defective. USB or PCMCIA wireless adapters are inexpensive and easy to install as a test. I have had good luck with the Trendnet USB adapters. For the router / access point, are there any other users who can connect without continuously being dropped?
  • Router / access point firmware maybe out of date, look for an update.
Mar 12, 2010 | HP Compaq nx5000 Notebook
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I trying to fix a small office network and need some help. I have a netgear ds116 hub that currently has a linksys WAP54G access point connected to it for wireless access. The access point is not encypted...
So have a hub and a wireless access point at office.
Do u have a router in the network at office ?
The default IP address of the WAP54G will be 192.168.1.245.
The Sonic firewall is a different thing.
I think you are accessing the set up interface of the sonic wall with the IP address 192.168.1.1.
Where is the access point connected ?
Is it connected to the sonic firewall ?
The access point does not have the DHCP server.
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WRT54GS Router...
SMC EZ Connect Access Point apparently not connecting to wired router
you doing something wrong there.
give the mac address of smc to the access point that's all you get it
Feb 18, 2008 | SMC EZ Connect (SMC2655W-KIT) 802.11b
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Repeater
The repeater must be the same brand as the signal it is repeating. Different routers / access points work in slightly different ways and the current generation of wireless repeaters aren't smart enough to work with other brands.
It's kind of like trying to put an engine from a Nissan Altima into a Honda Accord... both make the car move but they aren't the same inside.
Oct 31, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Can't get it to talk to my LAN in ad hoc mode
Is the AP connected to the router using a ethernet cable? Are you having similar issues when you connect wirelessly to the wireless router?
Feb 11, 2007 | D-Link AirPro DWL-810+ 802.11b...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
