Question about Canon ZR10 Mini DV Digital Camcorder
Canon ZR10 cassette will not eject. - Canon ZR10 Mini DV Digital Camcorder
5 Suggested Answers
SOURCE: cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Posted on Dec 30, 2008
SOURCE: Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Posted on Jan 03, 2009
  • 586 Answers
SOURCE: I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Posted on Jun 16, 2009
SOURCE: Canon UC8Hi ejects cassette when it is inserted
Canon UC8Hi: The cassette is not retained when the door is closed - it is ejected again immediately. IF it is not ejected, the ''EJECT'' light flashes.
Posted on Feb 14, 2011
My Canon ZR25mc when powered on now immediately bings an alert to EJECT TAPE. When I eject the cassette a bit of tape stays inside the camera. The rollers do not release all of the tape. I cannot do...
This is a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, adisloged pinch roller or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Apr 26, 2011 | Canon ZR25MC Mini DV Digital Camcorder
Can't get my ZR10 to download my video to my computer through my firewire connected to the DV in/out port on the camcorder.
Hi, May be you have defective software in PC. Please re install the software and try reconnection.
Regards,
Dec 17, 2010 | Canon ZR10 Mini DV Digital Camcorder
Canon ZR10 how many battery does have
This camera comes with a single battery pack.
Oct 30, 2010 | Canon ZR10 Mini DV Digital Camcorder
Canon zr10 mini dv camcorder - when I insert dv, it tells me to remove the cassette. It will not view or record. have tried different cassettes.
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Oct 22, 2010 | Canon ZR10 Mini DV Digital Camcorder
I can't eject a mini cassette on my canon dv960,pls tell me what to do?
Hi
Try to turn off your device and remove the battery for about a minute. Reinstall battery and check for physical damages on the mini cassette door and try ejecting the cassette
Thanks for using Fixya!
Hope this helps
Sep 17, 2010 | Canon MV960 Mini DV Digital Camcorder
Jul 28, 2009 | Canon Video Cameras
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Eats tapes!!
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Sep 26, 2008 | Canon ZR10 Mini DV Digital Camcorder
My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
Sep 01, 2007 | Canon ZR30MC Mini DV Digital Camcorder
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Canon ZR10 Mini DV Digital Camcorder Logo
150 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
