Question about Samsung Q310-34P Mobile Notebook
Samsung q310 not charging - Samsung Q310-34P Mobile Notebook
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 13, 2010
How to change, bypass, the HDD password on Samsung Model NP 300E5E
Samsung bios password removal - YouTube
? 0:48
https://www.youtube.com/watch?v=QSiUFFWQUOI
Oct 3, 2010 - Uploaded by ScruffyLionTv
Hey guys this is a password removal service free of charge just ... maybe the password is changed, becouse i remove hdd from laptop, ... Samsung Model No: NP300E5C-A011N SN No. ....Samsung NP-R519-JA06ZA 01921269501D289221 .... How to:Samsung Q310 BIOS Password reset / clear cmos ...
Nov 19, 2015 | Cars & Trucks
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Screen has darkend and wont get briter
Are you running on batteries? Has you laptop go into hibernation? You can adjust display dimming in power stttings, by right clicking the Batery icon in the taskbar notification area and opening the power settings. if that's whay you mean? I need more information to give a informed solution. If you plug in the laptop to AC does it change? Try re boot.
Nov 05, 2012 | Samsung Q310-34P Mobile Notebook
Windows vista
Yes you can get download recovery discs, Hiren's Boot Disc, BartPE, & Live distributions, such as Linux, or indeed the operating system install DVD. These all can be used to do so.
Jan 28, 2010 | Samsung MOBILE NOTEBOOK Q310-34G SYST2.0G...
If windows vista has failed on a samsung laptop is it still possible to retrieve files from the hard drive, if so how is this done?
Yes of course.
However the procedure is somewhat advanced and is better be done by an expert professional.
Also please note that if your laptop is under quarantee then trying the following steps can void your warranty.
However, you can try the following:
First of all you will need an external hard drive casing.
Turn your laptop upside down and unplug it from the power and remove the battery.
Then unscrew the screws where the harddrive is.
See this link for an image of where the harddrive might be and look like
(HARDDRIVE)
After you unscrew the small screws remove the plastic cover and you will see the hard disk. Genthly remove it and place it in the external hard disk casing for 2.5" drives.
Then you can plug in the casing via usb cable in another computer and transfer your data.
Jan 28, 2010 | Samsung Q310-34P Mobile Notebook
Samsung 310. Wont load up not even in safe mode, after a few seconds the screen goes black and the cursor appears and thats it. Relatively new computer. My main concern is losing the photos I have saved......
send it back to the manufacturers, they will take out the hard drive and repair the computer, the hard drive with all of your photo's will be put back in and your problem will be fixed!
Jan 27, 2010 | Samsung Q310-34P Mobile Notebook
Unable to install geforce 9200m gs.. already downloaded to the website
Is this a upgrade for this laptop / Or just your desires. Changing video on any brand of laptop can be time consuming and tricky.
Oct 10, 2009 | Samsung Q310-34P Mobile Notebook
Samsung Q310-34P Mobile Notebook Logo
355 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
