Question about Toshiba e-Studio 232 Black and White Copier
Error Code E920 When duplexing - Toshiba e-Studio 232 Black and White Copier
I have a 69.0 printer error on my HP5100dtn printer.
Hi Mary L,
Good day... This steps may be helpful for you. try sorting one by one steps...below
solution 1:
1.The duplexer side adjust has failed.
2. Turn the printer off and then on.
3. Reseat the duplexer assembly.
4. Replace the duplexer assembly.
solution 2:
1. The duplex printing unit is not functioning.
2. Turn the MFP off, and then turn the MFP on.
3.Reseat the duplexer.
4. Check the connection between the duplexer and the DC Controller.
5. Replace the duplexer.
solution 3:
1. Duplex mechanism failure.
2. Duplex slide adjust has failed.
3. Temporary error.
Hope this solve the problem...
Thanks in Advance.
Hp Error Code 69 Service Errors 69 Printer Repair Message
Sep 15, 2017 | Office Equipment & Supplies
Code 0 d50
Enter in Tech.Rep.mode by pressing Stop - 0 -Stop -1 ,select F code history open the front door and close.If the error code persist pull out the duplex unit and verify the duplex mechanical components.
Nov 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Datacard printer SP75 plus error code error DM-00762 (Duplex Jam)
Open the duplex module cover at the back of the printer (1).
Release any cards stuck in the module (2). Make sure that the duplex
mechanism can move freely in the direction shown
For more help visit cbrtechsolutions
Jun 20, 2013 | Office Equipment & Supplies
Error code 69.00
A printer error occurred where X is
detailed below.
0 The duplex mechanism failed
1 The duplex side-adjust failed
________________________________
1 Turn off the printer, and then
turn the printer on to
continue.
2 Reseat the duplexer (make
sure that the printer is turned
off).
3 Perform a service test. See
page 213.
4 Perform a paper-path test.
See page 213.
5 If the error persists, replace
the duplexer (make sure tha
Apr 22, 2013 | HP LaserJet 9050 Printer
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
My ricoh 2022 is giving me error code sc650 on my ricoh 2022 machine.
Communication timeout error between
SBCU and duplex unit
650 B
The SBCU cannot receive a response
within 1 second from the duplex unit.
• Serial line connecting SBCU and
duplex unit unstable
• External noise
• SBCU board and duplex main board
connection defective or loose
• Duplex main board defective
• SBCU board defective
Jul 22, 2011 | Office Equipment & Supplies
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
It says 57.7 printer error and cycle power to continue
By any chance do you have a duplexer on this printer? The error code says that the duplexer has a bad fan. Power down the printer and remove the duplexer. Power up the printer and see if the error code is gone. Replace the fan.
Nov 22, 2010 | HP LaserJet 4000n Printer
Error code 57.70 on HP 9500 color printer
What is the code? This unit does not have a fan in the duplexer nor for the duplexer. The 9500 has a fan housing but there was never a fan put in by the design team. Give the code and I look it up to see the problem.
Apr 28, 2010 | HP LaserJet 9500n Printer
Minolta EP4320 - How to clear the "Cd" error code
A "CD" code means some thing is not closed correctly or attached correctly. It has been a very long time scine I worked on one, but I believe that when you added the duplex unit there is a bottom part of the duplex unit that is held on with two screws at the bottom and one shoulder screw at the top. From what I remember is that if the bottom part of the duplex unit is not flush withe copier stand and the top part of the duplex unit the joggers will not move and there is a sensor flag that get stuck in the bottom part of the duplex unit. Also, di you connect all of the connector for the unit that goes inside the copier it's self. You are dealing with a copier that is over 10 to 15 years old. Good Luck
Feb 16, 2009 | Minolta CF1501 Copier
Toshiba e-Studio 232 Black and White Copier Logo
88 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
