Question about HTC HD2 Smartphone
My htc hd2 wont ring or vibrate even after i have did a factory reset
Go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
that should do it ;.)
Posted on Jan 06, 2011
  • ?imon Demo?ko
    ?imon Demo?ko Oct 02, 2011
    This is not the case. I had everything set like you said, even before. I reset it and it did not help. But it couldn't. The problem is, that when you have your mobile screen off, Viber as if couldn't take advantage of the device. I tested it with my friend. He called me w/ my screen off and it rang in his speaker, but my phone did nothing. While "ringing" I turned the screen on and immediately, my phone began to ring. If he sent me messages w/ my screen off, they did not do any sound or anything, but obviously, they were ready to be read and show notification in the moment of me pressing button to switch the screen on. So it's some sort of bug. We'd all love you to fix it somehow, Viber is just too awesome for us not to be able to use it.
  • ?imon Demo?ko
    ow ****, I'm terribly sorry, I thought this was about VIBER for android.. not the case.. ignore my comment..
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
Hd2 android,have to reinstall but it wont reinstall or reformat,just an error code of usb connection,no idea why.how can i format and reinstall? thanks
1. At you Home Screen, press the Menu button then tap "Settings."
2. Scroll down to "Privacy" and select it.
3. Now tap "Factory data reset."
Sep 23, 2011 | HTC HD2 Smartphone
I can't unlock my htc-hd2 phone it always ask me the passoword is incorrect. pls help me how to re-open my phone.
I'm sorry, but I think you will need to contact T-Mobile for support. Call them from another phone at 1-800-T-Mobile.
If you don't care much about the info on the phone, then do a hard reset to factory defaults.
http://www.hard-reset.com/htc-hd2-leo-hard-reset.html
CAUTION - DOING A HARD RESET, YOU WILL LOSE EVERYTHING ON YOUR PHONE. REMOVE THE MEMORY CARD BEFORE DOING A HARD RESET.
Good Luck,
Mark
May 15, 2011 | HTC HD2 Smartphone
I have htc-hd2 the problem is i cannot enter personal password. always ask incorrect password. my experience i used my htc-hd2 the was shut off then i charge my phone after the battery was full and i start...
Good Luck,
Mark
Do u know the unlock code for a htc hd2
Good Luck,
Mark
Apr 30, 2011 | HTC HD2 Smartphone
My HTC HD2 and I forgot my security code then i don't know how to solve the issues would you help me please?
Good Luck,
Mark
Apr 25, 2011 | HTC HD2 Smartphone
My HTC HD2 wont start, showed error with "cprog.exe" I'v tryed soft start, tokk out batary, but now I onslu come to HTC picture when starting up,, no buttons is function..
Good Luck,
Mark
Apr 22, 2011 | HTC HD2 Smartphone
My HTC HD2 is stuck on the homescreen, It want let me get in the start menu to get in settings to do a factor hard reset
You can do factory hard reset for HTC HD2 even when it is turned off. But it will erase all contacts,downloaded contents and user informations. The phone settings will be reset to factory default.
These are the steps to hard reset HTC HD2.
  1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it.
  2. Release the VOLUME UP and VOLUME DOWN buttons.
  3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 06, 2011 | T-Mobile Cell Phones
My HTC HD2 makes 7 vibrations then freeze.
Problem with the motherboard of the phone. Send it for repair. 7 vibrations is a error code " Heating up " Use ur phone in front of ac for testing :'
Feb 23, 2011 | HTC HD2 Smartphone
Hi I have htc hd2 and it is freez up in every minute. I bought in Florida and I live in Hungary. What can I do?
Update the firmware or reset it to factory defaults.
Good Luck,
Mark
Feb 09, 2011 | HTC HD2 Smartphone
HTC HD2 Smartphone Logo
681 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
