SOURCE: Trimmer Broke
Call this number; 1-800-736-4648 Or go to this link; http://www.remington-products.com/consumer/contact.htm Hope this helps :)
SOURCE: My Karcher pulses when on standby,stops when i use
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
SOURCE: My Russell and Hobbs Professional
it is important to check the continuity of the coil as the power indicator is a neon and will show up as the power comes to the circuit. So what is required is to check if the coil or the thermostat control is defective and so does not heat.
If you can contact the Russell hobbs web site - support and post the part code of the set it will be traced to be under warranty and it is possible that you can get support for help...just in case the coil has opened.
SOURCE: Remington body hair trimmer bought
If you want a replacement then you should have to contact " http://www.remingtonproducts.com/". Hope this will help you.
