Question about FUJIFILM FinePix S2500HD / S2600HD Digital Camera
Hi, I purchased a FinePix S2500HD recently and a Class10 32GB Adata SDHC card. The camera works fine with the internal memory when the SDHC card is not inserted. But when I insert the SDHC card, it comes up with "Card Error". When I proceed to format the card, it gives me "Protected Card" error. Is this because of any known incompatibility issues between the two? Any help on this issue will be appreciated. Regards, KK
    Brigadier General:
  • 11,967 Answers
The specs for your camera say that an SDHC card up to 8GB may be used....not 32GB!
Posted on Oct 12, 2010
  • KK Oct 12, 2010
    Thanks for your response. But when I checked the FujiFilm website "http://www.fujifilm.com/support/digital_cameras/compatibility/card/s/" and it states that SDHC cards from 4GB to 32GB are supported by S2500HD / S2600HD.
  • papabear213 Dec 17, 2010
    Check if write-lock is in correct position.
    They break very easy.http://www.camerahacker.com/Forums/Displ...
I bought a tevion 4 GB SDHC card but it wont work in my finepix a820 camera
Sorry, but the A820 was designed before the newer SDHC format card came out. Although it looks exactly the same as a standard SD card, the format its uses is very different. Sorry, but there's just no way that you can make an SDHC card work with your camera. You'll need to use a standard SD card only, those 2GB or less. Fortunately, 2GB standard SD cards are relatively inexpensive these days, as you can see from this link from Amazon.
For others reading with similar problems, but different cameras, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 26, 2011 | Fuji FinePix A820 Digital Camera
I have a Finepix A500 and keep getting the message "card reader error". How do I correct this?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Mar 18, 2011 | Fuji FinePix A500 Digital Camera
FinePix S2500HD it could not shoot take picture then no image?
if it shoots and then you have no picture make sure you have the memory card inside.
Mar 17, 2011 | FUJIFILM FinePix S2500HD / S2600HD Digital...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Camera can not read the memory card. Camera works fine on internal memory, but can not access the sdhc card.
Nov 18, 2010 | Panasonic DMC-TZ5 Digital Camera
When I start my finepix J10 camera it says "protected card". What should I do?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 08, 2010 | Fuji FinePix J10 Digital Camera
I have reinstalled the software several times.
1. Get a memory card. 2. Format the new card in the camera. 3. Go into the camera menu and find an entry for "copy" or some similar topic which would allow you to copy the contents of your internal memory to your new memory card. Once the pics are on the memory card, you should be able to download them to your computer.
Dec 10, 2009 | Fuji Cameras
Camera will not accept any memory card over 2GB. Keeps saying "Memory Card Error"
Most new 4GB and larger cards are SDHC cards (look on the card). Although they look exactly the same as a standard SD card, they are not. Unfortunately, there is no way that these cards will work with your camera, as it was designed before the SDHC format came out. As you've dsicovered, 2GB and less are standard SD cards, and will work with your camera.
There were a few standard 4GB cards produced a few years ago, most notably by ADATA (I have one that I use in my A620). Unfortunately, these are rare now, and are somewhat expensive if found on eBay.
Oct 11, 2009 | Canon PowerShot A620 Digital Camera
Will not recognize 16 GB SDHC Card - Help Please
I had a literally terrifying experience with Aiptek customer service.
I called up Aiptek to ask if it was possible to get my memory cards working. I have two 4GB SDHC PNY cards, which th ekid at target reccomended after loking at the back of the box.
I was told by aiptek tech support that PNY cards will not work in the A-HD camera.
When I mentioned that the box says it will take cards up to 32GB, and asked him if this was not false advertising. The representative became irate and started insulting me, using valgure language, and calling me a liar.
At this point I had enough of his abuse and yelled at him F.U!
What happened next is Truly Absurd and Outrageous!
The man behind the telephone at Aiptek told me he was going to send 5 guys to my house to assult me and my fammily!
THIS IS NO JOKE!
Jan 19, 2008 | Aiptek A-HD 720P Flash Media Camcorder
FUJIFILM FinePix S2500HD / S2600HD Digital Camera Logo
257 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
