Question about GE 36 in. Monogram ZGU36N4RHSS / ZGU36L4RHSS Gas Cooktop
Grill on my GE ZGU36L4RHSS cooktop will not light. Glow plug will not glow.
The grill gloplug will not glow. Do they typically go bad? Is it easy to replace? Where can I get one?
Also, the on/off indicator light for the grill control knob if very dim. When the cooktop was working well, the glowplug would glow for approximately 15-30 seconds then the burner would ignite. Thanks.
  • BOsborn1 Feb 24, 2009
    Grill will not light. No gas flow evident.
5 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Posted on Jun 20, 2009
heatman101
  • 43501 Answers
SOURCE: How to diagnose, remove and replace spark module
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
heatman101
  • 43501 Answers
SOURCE: grill will not ignite-glow pug is bright red
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
heatman101
  • 43501 Answers
SOURCE: 30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 30, 2010
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
I have a maytag gas stove model #MGR5775QDQ serial # 14863475CX the oven takes a long time to light and when it does it will not maintain a temp.
You have a bad ignitor to your oven. Part number you should replace is 12400035. This should fix this problem. Just because it glows does not mean it work correctly, it works off of the flow of electricity rather then the glow of the ignitor.
Ignitor How to test How to change ignitor
Good Luck
Aug 27, 2011 | Maytag Cooktops
Grill will not ignite-glow pug is bright red
heatman101
Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
Maytag clothes dryer flame won't stay lit
Usually this is the two gas valve solenoids, though it can also be a bad flame sensor or thermo. The solenoids are easy to change, they are right in front and usually have two screws holding them down. Order new solenoids by model number. Once you have the new ones you will see how they look and where they go on your gas burner. Just make sure you make not of the wire positioning and install the new ones the same way. Usually 3 wires on one side and two wires on the other. Parts are pretty cheap. Before I replace these I put an electrical testor on the solenoids to test if there is 120 volts coming in when the burner stops working. If their is 120 volts and the ignitor is glowing then you definitely have bad solenoids. Good Luck, Appliance Specialists.
Dec 15, 2009 | Cooktops
Also need black rubber feet for GE cooktop grill.
They are available at www.helpfulparts.com.
Referred to as GE Gas Range Cooktop Grate Foot Pad, $1.73 each
Jul 04, 2009 | GE Profile JGP636 Gas Cooktop
Indicator light will not go off.
usually means that the probe in that heating element has gone bad. it's no big deal but if it bothers you replace that element.
Apr 21, 2009 | GE 30 in. JP328 Electric Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
GE 36 in. Monogram ZGU36N4RHSS / ZGU36L4RHSS Gas Cooktop Logo
56 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
