Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
  • Philips Master
  • 8,457 Answers
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 12, 2010
Sont Projection Tv colors
Your red tube is weak or defective. If weak, gain can be adjusted up on the red tube.(cheapest cost) If red tube circuit is defective that will have to be fixed by a technician.(cost between $100 to $200) If tube is worn out, it will have to be replaced(250 to 500). Any work should be done by a qualified tech. Prices will vary depending on your area.
If set is over 5 years old, I recommend replacement.
Mar 13, 2014 | Televison & Video
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Mar 26, 2009 | Philips 51PP9303H Rear Projection...
Philips 9P6040C 60 in. Rear projection
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
60inch big screen philip t.v picture looks kind of orange in picture
crt coolant it tube is contaminated with a orange like fungus which is orange in color new coolant is needed.
May 01, 2008 | Philips 60PP9352 60" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
The colors off...
Wrong or poor color is usually caused by bad CRT's -----
each tube,red,green and blue must function properly for
good picture.Tube replacement is about 400.00 each....T.
Oct 27, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
