Question about Poulan Garden
Is it hard to change coil in polan leaf blower?
Is it hard to change coil in polan leaf blower? model no.mod:ppb430vs 711904
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: The cord came out of my Pouland Pro model PPb430Vs
I will give you instructions for fixing the recoil unit on a trimmer. The blower instructions are the same, just the configuration is different. The key is to maybe have someone help you.
OK...with the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope thru the housing hole and into the hole in the pulley.. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are done
Posted on Jun 05, 2011
  • 640 Answers
SOURCE: Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Posted on Aug 09, 2011
Where where do I get a exploded diagram of my Poulan Pro blower model ppb 430 vs. also assembly. in diagram that would show me how to put it back together
Here is a source for the exploded views. Enter your model number as "PPB430VS" and chose your type number. This type number is the last of the serial number after the dash.
Poulan Parts Lookup by Model
Apr 07, 2015 | Poulan Garden
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Aug 08, 2011 | Poulan Garden
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
48 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
