Question about Kenmore Washing Machines
Leaking front gasket to Kenmore HE2 plus - Kenmore Washing Machines
  • 1,342 Answers
How do I remove the door gasket and install a new one? I have the gasket but no instructions. I have a Kenmore HE2.
small inner spring in front lip of door gasket remove and then need to remove large rear band clamp loosen just little enought to pull off boot off clamp screw usually at 3 oclock position
Jan 31, 2011 | Kenmore HE2 Plus Front Load Washer
The gasket has been torn, it leaks water
replace the gasket can get from your nearest appliance shop or order from
Mar 16, 2010 | Kenmore HE2 Plus Front Load Washer
The washer leaks water just above the panel you can remove. What is the problem?
the tub seal gasket might be cut or your pressure switch hose might have a cut in it good luck
Feb 17, 2010 | Kenmore HE2 Plus Front Load Washer
I opened the door on my he2 plus 1104751 and a large retain type wire with a spring was there. I assume this goes around the tub seal to hold it on tight?
Yes, it is used to secure the bellows (door side) of the gasket to the cabinet. If the loop is still intact, you can use a pair of needle nose pliers to reinstall the retaining wire onto the gasket.
If the wire loop is broken, you'll want to get a replacement ASAP to prevent leaking and to prevent damaging the gasket too. They're available from or you can check for a local parts supplier if you wish.
Hope you find this Very Helpful and best regards!
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Open Questions:
Washing Machines Logo
403 people viewed this question
Sal De
 Brian Main
Brian Main
