A snail moves at a constant rate of 25 cm. per minute At this rate, how many days will it take the snail to crawl 75 m?
  • 2,567 Answers
5 hours.
Posted on Oct 13, 2010
When your pressure is132 youe heart rate is 75 and puls is 75 what tha mean
I am thinking what they meant to say was that your blood pressure is 132 over 75 and your pulse is 75. Blood pressure has two readings, a high and a low one. If this is the case, your blood pressure is fine and your heart rate (the number of times your heart beats per minute) is also fine!
Mar 31, 2017 | Health & Beauty
What should the average heart beat for a 65 year old man be?
The AHA says that the maximum heart rate during exercise roughly equals 220 minus age.
Age Target HR zone 50-85% Average maximum heart rate, 100% 60 years 80-136 beats per minute 160 beats per minute 65 years 78-132 beats per minute 155 beats per minute 70 years 75-128 beats per minute 150 beats per minute 7 more rows
Heart Rate: Normal Resting Heart Rate - Medical News Today
www.medicalnewstoday.com/articles/235710.php?page=2 average heart beat for 65 year old man Google Search
Mar 26, 2017 | The Health & Beauty
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Ways to get rid of snails..........Please help!! we have recently started a veggie garden and are so excited to see the progress. However, we see that the snails love the veggie garden as well. last...
Is beer non-chemical enough for you?
Look for snail trails around your plants. The trail looks like a glossy wet slimy line. Then take the hand trowel and dig a shallow hole to the depth and size of the non-breakable shallow bowl or pie tin in the area you see snail trails.
Pat the earth down around the hole so that It won't crumble into the bowl or tin of beer.
Set a non-breakable shallow bowl or pie tin in the hole.
Fill the bowl or pie tin with any kind of beer. Fill it slightly below the top so the snails will have to crawl in to get to it. Cheap beer works just fine. Once the snails are in the beer they are trapped.
Clear out dead snails and keep putting beer in the bowl every two or three days as it evaporates. You can put more than one bowl of beer out in other areas that are tempting to snails.
Basically, the snails love the beer, they fall in and drown.
Mar 08, 2014 | Garden
Math Problem: You have an upstream Picking department that feeds two downstream packing departments: A and B. 75% of your Pick volume goes to department A, which has a packing rate of 150 unites per labor...
Stream
Vol %
Units/Hr
Total Volume
Hrs Reqd
Staff Reqd
Pick
=(D3*B2)/B3
=D2/C2
=E2/10
Pack A
0.75
150
7500
=D3/C3
=E3/10
Pack B
0.25
25
=D2-D3
=D4/C4
=E4/10
Paste this in an Excel Spread sheet. After pasting it press CTRL+~.
Sep 01, 2010 | Computers & Internet
Alltel Bill question
On Alltel U prepaid, you get two free features for 75 cents a day, three for $1.00 a day, and four for $1.25 a day.
The four features offered are unlimited text messaging, unlimited night and weekends (N&W), unlimited mobile to mobile (M2M), and unlimited calls any one number. You decide which ones you want.
The fee is charged every day, regardless of usage or not.
The only way to not get charged every day is to switch to the pay-per-minute plan or get a monthly plan.
Dec 10, 2008 | Samsung Hue (SCH-r500) Cellular Phone
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
