Question about Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator
Jenn - Air JRSD 2250
It is about 10 years old and I have to keep manually defrosting the freezer.
4 Suggested Answers
SOURCE: Jenn-Air Refrigerator
my refrigerator keep warm and freeze work fine, but when i take the back panel off in the freeze the pipes are with a lot of ice on them. Once i defrost the pipes behind the panel it will work for two or three weeks and then its back to the same process. Help me please.
Posted on Dec 31, 2007
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 531 Answers
SOURCE: freezer iced up and refrigerator too cold
checkcoldcontrol or you have defrost problem
Posted on Apr 06, 2009
  • 121 Answers
SOURCE: I have a Jenn Air side by side and the drain at
You are going to have to get the drain good and clean. Take a turkey baser and force hot water down the drain until water flows freely. Once water is flowing freely mix water and baking soda and pour it down the drain. I hope this helps.
http://www.appliance-repair-it.com/Refrigerator-repair.html
Posted on Oct 21, 2010
Freezer coils icing up, refrig not cooling 8 years old expensive where is thermostat control
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Jrsd 249t top is warm... bottom freezing
Uncertain as to whether this is a "freezer at top or bottom" model? Make certain that temperature control settings are approximately at the one-half way for both the freezer and fresh food compartments. If freezer at bottom, you may have a defrost component issue (defrost thermostat or heater). If so, contact an appliance service company.
Feb 10, 2010 | Refrigerators
Jenn Air freezer does not 'automatically defrost-side by side
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
The refrigerator is 8 years old. the refrigerator
Any refrigerator should last around 14 yrs. The freezer must be frosted up. I would try to defrost it and then start it back up. If you have a defrost problem you will see this again inside of a week. Also make sure the evaporator fan is operating.
Jun 18, 2009 | Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air JRSD 226 side by side Fridge
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Aug 29, 2008 | Jenn-Air JCD2389G Side by Side...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn Air (french door freezer on bottom) icemaker - 2 years old
the water supply in the unit may be blocked or frozen up at some stage, i would try a full defrost for 36 hours and then try it out.
Jun 06, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator Logo
204 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
