Question about Car Audio & Video
Horn stopped working, replaced relay fuse and still no sound. Where is the horn located on a '96 monte carlo?
    Scholar:
  • 50 Answers
You will find it on the passenger side and underneath the car near the front tire well. If you lay down and look up from under the bumper you should be able to see it. Let me know how you do.
Posted on Oct 12, 2010
Hello. Horn in 03 Monte Carlo isn't working. Replaced both fuse and relay. Removed and checked the horn and it still sounds but no results. Please help.
Find a facility with a scan tool that can access the Body Control Module. They will need to look at the data. Ideally the scan tool will have bi-directional control. You should be able to watch the horn be pressed via the scan tool in the Body Control Module. If you can see it is pressed, but no horn sound, try to operate the horn via the scan tool. GM supports this functionality test. If the horn does not operate, check the horn relay. It could be a broken wire between the BCM and the fuse box, or between the horn contact switch and the BCM.
Mar 06, 2017 | 2003 Chevrolet Monte Carlo
Horn relay
it should be in the fuse box.
Oct 05, 2013 | 1985 Chevrolet Monte Carlo
Horn on my 2003 monte carlo stopped working. The volume got weaker and weaker until finally no sound is made when you press the horn
do you hear a click sound from a relay when pressing on horn button? most likely is underhood. if so,locate the horn(s) and test voltage with a test light or DVOM at the horn + side. if both have voltage,check - side.(ground).if both are correct replace both horns.
Sep 27, 2011 | 2003 Chevrolet Monte Carlo
Location of horn relay on 1983 monte carlo
HORN RELAY IS IN THE FUSE BOX UNDER THE INSTRUMENT PANEL NEXT TO STEERING COLUMN.
Jul 05, 2011 | Chevrolet Monte Carlo Cars & Trucks
What fuse do I need for a horn on a 1999 monte carlo
the horn has a 15 amp fuse, there is also a horn relay.
Jun 10, 2011 | 1999 Chevrolet Monte Carlo
I have a problem with my pcm on a 96 monte carlo. every three or four days the control module fails to power up and the car wont start for a couple of days. is it a power problem or a module problem? what...
There was a problem in the 96 luminas with the Ignition relay in the under hood fuse box.
I would try trading the Ignition relay with a matching relay in the fuse box and see if the problem goes away, make sure you mark the old ignition relay so you can find it later. If the problem stops, purchase a new relay and replace the old one.
Below is a schematic of your under hood fuse block.
Good luck, let me know.
Regards,
Oct 12, 2009 | 1996 Chevrolet Monte Carlo
Can't find the fuse box for a 96 Monte Carlo
The fuse box is located on the passenger side panel of the dash . you have to open the passanger door to get at it.
The other fuse boxes are under the hood, on each side under a diagonal support arm that has to be removed to get at the fuses & relays
Jun 07, 2009 | 1996 Chevrolet Monte Carlo
96 Monte Carlo Fuse
look under the hood. take the top of the fuse box and look at the sticker on the inside of the top. It should tell you unless the sticker ore off. Otherwise look in a Chilton's manual at your local library.
Jan 21, 2009 | 1996 Chevrolet Monte Carlo
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
