Question about Sony SPP AQ600 Cordless Phone
How do you set the time and date on the phone?
Where is OK button when setting date and time
Correct my date and time to update my phone ' Windows ...
www.windowsphone.com/.../correct-your-date-and-time...
Windows PhoneIf you're having trouble installing a Windows Phone update, correct your date and time settings manually.
How to Change the Date in Android ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
Android phones normally pull the date and time from the Internet, but if there's a problem with the signal ... Click the "Settings" button to open the Settings menu.
2013 Models - How to Set the Date and Time on your ...
? 0:52
https://www.youtube.com/watch?v=jTSZwCLSiTk
Dec 4, 2012 - Uploaded by Panasonic Canada Help
In this video we will explain how to Set the Date and Time on your Panasonic Cordless telephone, models KX ...
How to Set the Date and Time on Your iPhone - For Dummies
Dec 26, 2015 | Lands Phones
Geemarc ampli600 manual
hello Jennifer Huffman
If your phone is android support
1. Go to Settings
2. Select Date & Time
3. Select Set Date ( This is where you can set the date) and set
4. Select Set Time ( This is where you can set the time) and set
If your phone is Java support
1. Go to Settings
2. Phone Settings
3. Time and Date
4. Set Time and Date (Don't forget to save)
For more info about phone
visit my blog: chadcircle.blogspot.com
Mar 03, 2014 | Lands Phones
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
How do change time by one hour say 2.30 to 3.30 7020 phone
Select Menu > Settings > Date and time. To set the date and time, select Date & time settings. To set the formats for date and time, select Date & time format. To set the phone to update the time and date automatically according to the current timezone.
You can get more help from downloading the manual from Nokia at http://nds1.nokia.com/phones/files/guides/Nokia_7020_UG_en.pdf
Mar 13, 2011 | Nokia Cell Phones
How to set time and date on cell phone
go into the menu,go to initial phone set up.the time and date settings will be there,most phone will pick up the time and date from your service provider .
May 18, 2010 | Cell Phones
How do i set the time on my nokia 2630
Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
Aug 05, 2009 | Nokia 2630 Cellular Phone
Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
Mar 25, 2009 | Motorola Cell Phones
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sony SPP AQ600 Cordless Phone Logo
21 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
