Question about Sharp AR-168D Copier
Appears this message: SYSTM ERROR [O4-00] REFER TO USER GUIDE the model is: SHARP AR-168D
007tech
  • 95 Answers
SOURCE: I have an error code of L3-00 on my Sharp AR 168D.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Posted on Mar 26, 2009
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
SOURCE: Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Posted on Feb 11, 2010
hamzaskilltd
  • 316 Answers
SOURCE: AR-235 Grayscale Copier: I use Sharp AR-M150 3-in-1 Copier. I was scaning a...
heat roller low temperature detection
Posted on Jun 05, 2010
hamzaskilltd
  • 316 Answers
SOURCE: I use Sharp AR-M150 3-in-1 Copier. I was scaning a...
Posted on Jun 12, 2010
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
How do you reset the error message : maintenance requred, call a service technician?
You call a Sharp Service Technician and have them reset it. That code cannot be reset by a user.
Oct 08, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Jan 12, 2009 | Sharp AR-168D Copier
Systen Error L1-00
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, and turn the power back on.
If this don't work, turn off the power
and wait 10 seconds to reset.
Mar 26, 2008 | Sharp AR-168D Copier
Sharp AR-168D Copier Logo
177 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
