Question about Electrical Supplies
No spark on homelite genarator model 174a27-1b
What is the Gap set to on the RCJ6Y Homelite trimmer
25 thou. 0.0025
OPERATOR'S MANUAL MightyLite 26cc VersaTool String Trimmer ...
https://www.gardnerinc.com/manuals/.../Homelite/string%20trimmers/.../UT21566_96...
Your trimmer has been engineered and manufactured to our high standard for dependability, ease of operation, and ..... Mix Homelite Premium Exact Mix lubricant with gasoline .... This engine uses a Champion RCJ6Y or equivalent spark.
SOLVED: The sparkplug RCJ6Y can you tell what the gap is - Fixya
www.fixya.com/support/t6293374-sparkplug_rcj6y_tell_gap Oct 5, 2010 - The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar ... gap champion rcj6y spark plug Questions & Answers ...
Apr. 1, 2015
Weed eater spark plug gap for champion rcj6y for ...
Jun. 16, 2012
SOLVED: What .000s is gap for champion plug RCJ6Y
Aug. 28, 2011
rcj6y champion Questions & Answers (with Pictures)
Apr. 17, 2011
More results from www.fixya.com
Jun 04, 2018 | Homelite Garden
What is a replacement spark plug for the Homelite DJ168F-18500A plug provided with this unit?
HOMELITE DJ168F-18500-A - SPARK PLUG - Part Number ...
www.smallenginesprodealer.com/homelite/.../homelite-dj168f-18500-a-spa...
HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ... This is an original approved HOMELITE replacement part.
A100643 - SPARK PLUG - Part # A100643 - Small Engines ...
www.smallenginesprodealer.com/homelite/.../a100643-spark-plug-part-a...
This is an original approved HOMELITE replacement part. ... HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ...
HOMELITE GM304012 - SPARK PLUG A - Part Number ...
Jan 18, 2016 | Homelite Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Proper spark plug for homelite mdl ut2oo series weedeater
  • MFG Brand Name : Ryobi/Homelite
  • MFG Model # : AC00160
  • you can get them at any Home depot or any hardware store
Jul 04, 2011 | Homelite Mighty Lite Lawn Trimmer
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Spark plug gap on homelite 16 inch ranger chainshaw
I don't have access to an Operator's Manual and they don't appear to be available on line, I checked several different Homelite models at Chain Saw Collectors Corner. All said 0.025". HTH
Lou
Oct 11, 2009 | Homelite Garden
Type of spark plug to use on model 046396207081 Homelite string
Champion RCJ6Y or equivalent -- gap to .025 inches.
Charlie
Oct 01, 2009 | Homelite Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Electrical Supplies Logo
75 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
