My mcconnell hedge cutter pump gets very hot after 4 to 5 hours working and controls get slow,is this normal and would an oil cooler help
SOURCE: volvo xc90, oil in water
How's the fluid looking on the transmission dipstick?
Posted on Aug 16, 2008
emissionwiz
  • 76164 Answers
SOURCE: TRANSMISSION OIL COOLER
Change the fluid and filter, use synthetic trans fluid, you may cure your issue this way, have you run self test on the trans for trouble codes?
Posted on Sep 02, 2008
venexcsd
  • 1185 Answers
SOURCE: b&d hedge cutters not working
You need an ohmmeter or a buzzer to check for continuity through the machine
Start with the fuse in the plug top (If fitted) and see if that has blown, use a low ohms reading or a buzzer.
Easier to insert a new fuse
Put a test lead on the live and neutral pins of the plug and press the trigger , you should get a reading if the circuit is made
If there is no circuit then remove the plug from the socket and then the the covers from where you re-wired the cable
Check to see that you have not fastened down the outer sheath of the cable instead of the inner wire when you placed the ends into the connector block.
Next test
Put a probe on one pin of the plug top and the other into the corresponding wire on the terminal block inside the cutter , if you get a reading swop to the other pin and the other cable and test that one out
If they show a circuit then put the probes onto where they leave the connector block and press the trigger , no circuit then means you have blown up a component
Posted on Sep 21, 2009
SOURCE: I am after the petrol/oil
my BRUSH CUTTER PBC3020Y wili start but cuts out when attempting to increase revs
Posted on May 13, 2011
  • 4 Answers
SOURCE: what ratio of oil do you reccomend for the
Look on the fuel filler cap it should tel you mine says 40:1
Posted on Mar 13, 2012
Engine runs hot and stays hot 4 hours after.
HI Jerry, and the usual suspects are:
1. Insufficient oil supply or oil not circulating.
2. Leaking valves.
3. Heavy carbon deposit in combustion chamber.
4. Ignition timing retarded.
5. Normal engine oil tempurature 180-220 degrees.
6. No oil cooler.
Good luck
Aug 06, 2013 | 2009 Harley Davidson FLHRC Road King...
My engine runs very hot when stuck in traffiic or at very slow speeds,the fan starts ok but it gets to the stage that the engine starts to miss fire,i have flushed the system and added Water Wetter but...
Your engine is getting hot enough to overheat the carburetors. That is why it is running poorly when it gets really hot. You have a classic problem normally only associated with air cooled engines. If you are in hot conditions, in stop and go traffic you have the same options as an air cooled bike. Turn it off and let it cool down (the fans will continue to run on most bikes) which will help but may run down the battery. The other option is to find another route that keeps you moving even if at in town speeds. If your mixture is set lean that can cause extra heat. If you have put on different exhaust pipes with out rejetting that can make you run lean/hotter. If you have opened the air box and put in a K&N air filter that can make you run lean/hot. If an oil cooler or bigger oil cooler is available that will help lower your engine temperature. Running synthetic engine oil and synthetic hypoid gear oil (in the final drive) will also lower engine temperatures. Try a spark plug one heat range colder. This is recommended in the owners manual for hot weather driving. Every little bit helps.
Sep 04, 2011 | Yamaha V-Max Motorcycles
I have an 8104 type 7 black and decker hedge trimmer. It freezes up durning the cutting or just squeezing the trigger. Makes a loud buzzing noise. Almost like it is jammed and there is nothing jammed in...
Did you ever oil the cutters since you have owned it? Try this spray some PB Blaster on the cutters let it soak and then try running it. If you can't find that stuff just try some motor oil, pour it on let it soak and give it a whirl. Good Luck...
Aug 24, 2011 | Black & Decker Decker Ht018 18" 26...
Have recently bought a 2 stoke ( 1 part oil to 50 petrol) hedge cutter. Prime it in start position 7 times as reccommended. But terrible problems starting it. Have used it 3 times and it takes up to half...
If you are not using fresh fuel, change the fuel and replace. Although you will still have fuel in the carburetor and the lines. If you do not remove and drain it may take a little while to get it to start, but should be a lot less then what you are doing now.
Aug 20, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
After running for a few hours it gets hot and shuts down but runs fine every morning
Without more info I will have to give you several things to look at. Typically during the hot months rotary units experience temperature shut downs due to the following. Dirty oil coolers. Blowing them out with air my help some but ideally they need to be washed using a degreaser solution. Location. during the hot months poor air flow/ air removal may let heat from the compressor build up in or under the cover or room. This hot air gets drawn in by the compressor and raises the compressor temperature. The cycle continues until the compressor shuts down on high air temp. Maintenance. Poor maintenance on rotary screw compressors leads to shut downs on high temp, high air temps then play havoc on dryers which causes moisture in the air system. Maintenance items that need replacing regularly ( about 2000 hrs) oil filter, air filter, Depending on type of oil used change 2000 to 8000 hrs, seperator @ 8000 hrs. Also the amont element will cause high temps if bad. It is located where the three oil lines come together. There should be 4 screws that hold the cover on. the cover also has a hose connected to it and located close to the oil cooler. This amont element acts like the thermostat in your car. it lets oil bypass the oil cooler or causes more oil to go thru the cooler. the cooler oil and bypass oil mixes and maintains a certain temp. air end temp should run about 195 F and injected temp about 165 F. hope this helps. if you can give more detailed info I can get you closer to your problem.
Jul 13, 2011 | Air Tools & Compressors
Can you tell me fuel mix for gh24 hedge cutter please
32 parts gas 1 part 40weight sae oil
did you know all 2cycle oil is 40W SAE? ?
Dye is added to it to fool everyone so they buy the colored oil
Jul 07, 2011 | Garden
My hedge cutter smokes
Your hedge cutter is toast....motors run on smoke and when the smoke comes out they no longer run....:-)
Given that a hedge cutter is not all that much money to replace... trying to repair it will not be worth it...
Your best bet is to just get a new one...
heatman101
Oct 10, 2010 | Garden
Mcculloch hedge cutter..... Ratio of oil to petrol please ? 4 litre tank
Hi Guest,
The ratio is the same no matter the tank size or unit of measure.
40:1 petrol to oil
Best regards
Host
Jun 28, 2010 | Garden
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
Ryobi 18V Hedge Trimmer Blade Question
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Aug 27, 2008 | Ryobi 18V Hedge Trimmer
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
