Question about Frigidaire Over-the-Range Microwave
In my owners manual for Frgidaire model CFMV156DCC it explains how to change the light bulb under the oven but not the burnt out bulb that illuminates the interior. Can you provide instructions for this procedure. Sincerely, Stan Scott
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: light bulb change
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Frigidaire owner's manual and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 03, 2008
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Change light bulb microwave
If your owner's manual doesn't cover it, then you will have to do some disassembly, and may have to remove the oven from the wall, depending on the model number, which you did not mention.
But since you posted this is the Whirlpool microwave section, I'll assume that's it.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 17, 2013 | Whirlpool GH5176XPT microwave Oven
How do i replace the bulb for the under light
The owner's manual covers that.
It depends on your brand and model, which you did not mention.
You can download GE owner's manuals and installation instructions here.
Apr 14, 2013 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Light has burnt out
R-820BK/BW Microwave Operation Manual
Due to the risks of death or serious injury the above owners manual suggests that a burnt out light demands a service call by a qualified technician.
That said, if you have a basic level of competence and read the safety hazards involved with microwaves (see a good resource on microwave safety and repair at:
http://www.kellerstudio.de/repairfaq/sam/micfaq.htm
Often, the microwave is divided into two main compartments, the electronics compartment(usually immediately behind the front control panel), and the high voltage compartment(usually behind the electronics compartment). The light bulb is likely in one of these two primary compartments. If it is in the high voltage compartment with the HV Capacitor and magnetron, changing the bulb becomes much more dangerous.
Please be very careful if you do decide to do this on your own... unlike most electronics microwaves can remain lethal, even when unplugged. Hope this helps.
Oct 21, 2010 | Sharp R820BK 900 Watts Convection ...
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Daewoo KOR 1B4H microwave light bulb burnt out. Can I change this myself?
It probably is, but I cannot find your model number on the Daewoo website to look in the manual.
Please confirm and reply the model number .
Jan 28, 2009 | Daewoo KOR-1B4H Microwave Oven
Ummmm I feel stupid
The manual is on the Emerson site at:
http://www.emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
But it doesn't seem to mention a way for you to change the lamp.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 18, 2007 | Microwave Ovens
Frigidaire Over-the-Range Microwave Logo
91 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
