Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
HI I HAVE POULAN 3500 CHAIN SAW I CHECK THE AIR FILTER CLEAN GAS HOSES FINE SPARK CAMING FRESH GAS ICANT FIGURE AUT. MAYBE DAIGREM.
  • 7,733 Answers
Here -->link eRP.
Posted on Oct 14, 2010
My saw is less then one year old. The saw will not start, it has a new spark plug fresh gas. The saw was running fine and just sputered and cut out.
You need four main things for the saw to start, good compression ( remove the muffler and check the condition of the piston through the open exhaust port, look for signs of scuffing on the piston skirt ), a spark at the plug ( remove the plug, place it ontop of the cylinder, or a good earth, crank the engine and check for a spark ), a spark at the correct time ( remove the flywheel and check the key has not sheared, check the air gap between the flywheel and the ignition unit, this should be 0.3mm ), fresh fuel at the plug ( when you remove the plug, is there signs of fuel on the plug electrode, if not there is a fuel blockage, check the fuel filter in the tank, check the fuel hoses for signs of leakage, or cracks )
Sep 17, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
It strats wount idel or reve up it ran fine till got dirt in the carb it got cleand and now this
sounds like you still have a dirty carb but.I'd change the plug. clean the air filter. check the fuel screen in the fuel tank, make sure it is fresh fuel, if none of this works I would think your carb is still dirty or out of adjustment.
Feb 23, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Wont start
Remove the spark plug and check for spark. If snappy and blue with a fresh plug gapped at 0.020", then pour a little fuel mix into the plug hole and try for start. If it pops or runs for a few seconds, then look for fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Inspect the diaphragm in the lower chamber for flexibility with no holes or cracks. Make sure the fuel is fresh and properly mixed with a modern synthetic saw oil. Be sure to shake the container thoroughly each time time just before filling the tank to prevent oil starvation. Hope this helps!
Jan 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 3500 wont start
Try putting in fresh gas. Change spark plug. Clean out air filter.. Check choke for proper operation. Make sure it is getting spark and fuel.. Hope that helps dont know what you have done to the saw.
Jul 06, 2009 | Garden
Saw does not idle and is hard to start. It is a P3314 Poulan
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Jun 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Will not start
Hi, do you pump the primer til is's full before starting?
Mar 18, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My Poulan 3500 chain saw will not start
My guess is that one of your fuel lines has a crack or small hole in it. Inspect these and replace if needed. let me know how it goes.
Feb 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan saw will not fire
Hi
Check if the gas tank cap vent is plugged.Check if the flyweel key is sheared(ignition timing point).Check the fuel filter and air filter.
Hope this helps.
best regards savumihai71
Dec 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
77 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
